PO513 code
PO513 code
Guys,
My 08 Dodge is throwing this code, SKEEN issue.
Has anyone had a key reprogramed ?
Is the R&R of ignition module ever helped here?
Thank You
My World
Thank You
My World
P0513-SKIM INVALID KEY ERROR
This is part of the security system and will throw the code if you start the truck and then restart it without pulling the key. For example, stopping at a drive through for lunch and shutting the truck off to listen to the person take your order. Then restarting the truck to move toward the pickup window. That is one example of why this code is initiated. I have included the P0513 diagnostic procedure for your review. Hope it helps.
For a complete wiring diagram, refer to the Wiring Information.
When Monitored:
Key on.
Set Condition:
Invalid Key Code received from SKIM Module.
Possible Causes
GENERAL NETWORK ERROR
KEY NOT PROGRAMMED
INCORRECT KEY
INCORRECT VIN IN ECM OR SKIM
LOSS OF COMMUNICATION BETWEEN ECM AND SKIM
Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 28 - DTC-Based Diagnostics/MODULE, Engine Control (ECM) - Standard Procedure).
1. ACTIVE DTC
1. Ignition on, engine not running.
2. With the scan tool, read the ECM DTCs.
Is the DTC active at this time?
Yes
Go To 2
No
Go To 6
2. NO COMMUNICATION WITH SKIM
1. With the scan tool, attempt to communicate with the SKIM.
Can the scan tool communicate with the SKIM?
Yes
Go To 3
No
Refer to Section 29 - NON DTC DIAGNOSTICS - COMMUNICATION and perform the appropriate No Resonse test. (Refer to 29 - Non-DTC Diagnostics/Communication - Diagnosis and Testing)
Perform SKIM VERIFICATION. (Refer to 28 - DTC-Based Diagnostics/MODULE, Wireless Control (WCM) - Standard Procedure).
3. SKIM TROUBLE CODES SET
1. With the scan tool, check for SKIM DTCs.
Are any DTCs present in the SKIM?
Yes
Refer to Section 28 - DTC BASED DIAGNOSTICS - WCM and perform the appropriate Diagnostic Procedure. (Refer to 28 - DTC-Based Diagnostics/MODULE, Wireless Control (WCM) - Diagnosis and Testing)
No
Go To 4
4. VIN PROGRAMMED INTO ECM
1. With the scan tool, display the VIN that is programmed in the ECM.
Has a VIN been programmed into the ECM?
Yes
Go To 5
No
Program the correct VIN into the ECM and retest.
5. ECM
1. Turn the ignition off.
2. Replace and program the SKIM per Service Information.
3. Ignition on, engine not running.
4. With the scan tool, erase all SKIM and ECM DTCs.
5. Attempt to start and idle the engine.
6. With the scan tool, read the ECM DTCs.
Does the scan tool display this code?
Yes
NOTE: NOTE: Before continuing, check the ECM harness connector terminals for corrosion, damage, or terminal push out. Repair as necessary. Replace and program the Engine Control Module per Service Information.
No
Test Complete.
6. IGNITION KEY
NOTE: You must obtain the SKIM pin number.
NOTE: This DTC could have been set if the SKIM harness connector was disconnected, or if the SKIM was replaced recently.
NOTE: All keys that the customer uses for this vehicle must be tested to verify they are operating properly.
2. Verify the correct VIN is programmed into the ECM and SKIM.
3. Turn the ignition off.
4. With each customer key turn the ignition on and crank the engine to start.
5. With the scan tool, read the ECM DTCs. Look for P0513.
Is the DTC P0513 still active?
Yes
Replace the Ignition Key.
No
Test Complete.
NOTE: If this DTC cannot be reset, it could have been an actual theft attempt.
When Monitored:
Key on.
Set Condition:
Possible Causes
KEY NOT PROGRAMMED
INCORRECT KEY
1. ACTIVE DTC
Yes
Go To 2
No
Go To 6
Yes
Go To 3
No
Yes
No
Go To 4
Yes
Go To 5
No
5. ECM
Yes
No
Test Complete.
6. IGNITION KEY
Yes
No
Test Complete.
SwingingCCattle
Dec 26, 2006 12:46 PM
CTD NUT
Apr 5, 2005 04:45 PM
