Overhead Temp Gauge
Old Oct 7, 2004 | 08:30 PM
sajigore's Avatar
Arrow Overhead Temp Gauge
I keep noticing that my overhead is usually 5 or so deg off, usually higher. Does anyone know where the sensor is to clean it. I have an 04.5 CTD.
Old Oct 7, 2004 | 09:02 PM
Mike12345's Avatar
To locate the outside temperature sensor:
Raise the hood. The sensor is located about six inches above the bumper and four inches to the left of the headlight assembly. You will notice the wire loom running to the sensor. There is no adjustment. If the truck has been running and then parked for a while the sensor may pick up a false reading from the hot engine but once the truck is moving again the sensor should read ok.
Old Oct 8, 2004 | 12:30 AM
SuperGewl's Avatar
According to the manual it takes about five minutes to give you an accurate reading after it has been running and the truck is moving. You may need to calibrate the overhead if it is not reading correctly. Check the manual it tells you hoe to do it.
Polarlys
Nov 29, 2009 04:17 PM
H8GAS
18
Aug 3, 2007 06:31 PM
H8GAS
14
May 12, 2007 07:29 AM
tenmile
Jul 19, 2006 04:44 PM
