new ctd owner
Old Jul 16, 2004 | 07:21 AM
ccw55's Avatar
new ctd owner
Is it ok to put fuel additives in a new engine? I have 1300 miles on the clock. And if so, what brand do you recommend? Also would like to know if an exaust tip of some sort would keep the soot from building up on the rear quarter panel above the tailpipe?
Thanks Wayne
Old Jul 16, 2004 | 08:26 AM
Jeff in TD's Avatar
I don't think a quality additive will harm the engine, but I personally don't run an additive so I will let someone with personal experience chime in as far as what brand.
I run a Megs tip from Gino's. I chose it because it is stainless steel, and also I like the look of no clamp (friction holds it on). It doesn't quite eliminate all soot, but if I scooted it out and secured it with a screw it probably would. What soot gets on there is easy to remove, so I haven't bothered.
If you search for "megs tip" I think there were a couple of threads with photos.
Old Jul 16, 2004 | 09:25 PM
SuperGewl's Avatar
Re: new ctd owner
Thanks Wayne
Personally I don't and want run any brand of additive.
As far as the soot you get on the rear quarter panel, yo can either drive faster or try a different brand of fuel. I have noticed that when I fill up at some places I will get it and at some I don't.
Right now I don't get it because of the Banks Six Gun is giving me better mileage and ensuring a full burn of fuel.
Old Jul 17, 2004 | 07:44 PM
moterhead's Avatar
I bought a Meg's from Geno's. Mine was too loose a fit to stay on without a clamp. I had to slit it a couple of times and use a big hose clamp to keep it on. They are too pricey to lose going down the road. I have mine pulled out enough to prevent the bumper from sooting up (hopefully). I don't really like the look as my truck is a flame red sport. No other shiney stuff on it, but like the soot even less. If it doesn't do the job, it'll come off.
Old Jul 17, 2004 | 09:25 PM
Hannibal's Avatar
Be careful with those additives. If the additive desperses water, the fuel water seperator can't do it's thing and will allow water to pass on to the injectors. Water in our new high pressure injectors can literally blow the tip off the injector. The heartache of it is it's not covered under warranty. Best to try to buy fuel from clean stations that do a lot of business so you know the fuel is fresh. I don't use any additives and don't plan to unless it's from Cummins. But that's only my humble opinion...
truckroc
Introductions / New People
Jun 10, 2017 02:57 AM
92GhostRyder
Aug 11, 2010 08:31 AM
drivrswntd
Jan 31, 2006 08:22 AM
WSmalley
Dec 10, 2002 06:18 PM
WSmalley
Dec 6, 2002 04:17 PM
