leveling kit problems and questions..
Old Aug 13, 2007 | 03:42 PM
Ga_Mike's Avatar
Question leveling kit problems and questions..
Hey guys I have a '07 3500 dually. I just installed a spacer leveling lift kit in the front end of my truck along with bilstens 5100's. It now makes a popping noise when I hit bumps and the front end is alot more bumpier...Any help
Old Aug 13, 2007 | 04:03 PM
Ga_Mike's Avatar
Oh i forgot...I doubled checked to make sure everything was tight and it is....Thanks
Mike
Old Aug 13, 2007 | 04:07 PM
bsj04's Avatar
check track bar bolts. there known for not being tight enough. put a breaker bar on them, even if the think there tight put some more in to it. i know you already checked everything but do it one more time.
Old Aug 13, 2007 | 08:07 PM
rjelliott's Avatar
sounds like you left something loose somewhere.
Old Aug 13, 2007 | 09:02 PM
Ga_Mike's Avatar
Hey guys i found it.....I forgot to put rubber piece on top of shock tower......I feel like a $@#^...LOL.....Thanks for replys!
Old Aug 14, 2007 | 07:12 AM
gpshemi's Avatar
How does it drive? Ride any better?
I've been thinking of the same change. 2" TopGunz in front with 5100's and then a 2" spacer in the rear with 5100's. Did you have it aligned after?
Old Aug 14, 2007 | 09:50 PM
Ga_Mike's Avatar
Exclamation
Well to be honest with you it flat out %$#^....I still have to get it aligned but i had the death wobble happen to me twice today...Talk about scary!!!....Felt like i was going to bouce or wobble off the road..All most like since the geometry change to suspension the shocks can't hold down the tire...Who knows.....I rechecked all hardware and its all tight. WHO KNOWS...ANY SUGGESTIONS....
Old Aug 14, 2007 | 09:59 PM
skynyrd's Avatar
if you haven't had a shop do the alignment on it yet then your toe is off and both front tires are pointing inward. and you track might be off as well.
Old Aug 14, 2007 | 11:52 PM
Ramified5.9's Avatar
Had the exact same problem on my '06 Dually. Even after alignment, the DW was the same. I had found the steering stabilizer was faulty (even with 3500 miles on it). I changed it out to Superlifts Dual unit that used Bilstein's for the dampners. My set up was exactly like yours. 2" leveling kit, Bilsteins 5100's etc.
I have since transferred all these components to my new '07.
sgtdiesel
25
Jun 26, 2012 02:37 PM
CalypsoCowboy
Oct 22, 2009 12:52 PM
onebadrubi
31
Dec 16, 2007 09:59 AM
budsowner
Jul 10, 2005 01:45 AM
henchman
57
Aug 2, 2004 11:49 AM
