Installing Back-up Camera, need wiring help
I am installing a new Alpine DVD Headunit with associated back-up camera. The head unit needs to be connected to the brakes, parking brake and reverse lamps. Does anyone know which wires under the dash these may be? I should be able to find the parking and brake wires under the dash, but I don't know where outside of the backup lamps or trailer wiring harness to try and find reverse lamp wire inside the cab. Do any of you have any recommendations/solutions?
Thanks in advance, D |
Here is a place where you can download the electrical for your year. There is also a lot or other information. The file is big, I downloaded everything first then look up stuff. http://www.dodge.com/bodybuilder/year.pdf
take the one for the parking brake and ground it, that way you can watch DVDs and adjust your NAV without it being in park. PS I don't condone watching DVDs while driving, but its nice for the kiddos to be able to watch a DVD while driving.
I used the wiring at the taillights for the reverse signal. It's a white wire with lime green stripe...becareful though, cause there's also a white wire with a hunter green stripe in there.
--Eric |
i found the reverse wire at the HUGE junction box, behind the front tire, you will see the huge terminals.
Eric is right - be CAREFUL which wire, and double check it and yes, ground the parking brake, that way your wife can put in an address while you drive (you can put a switch on the parking brake lead, that way, if someone borrows your truck - they can't watch movies while driving) |
Thanks for all the information. The Alpine headunit looks like it involve a bit more then just grounding the parking brake, it also involves a connection to normal brake lights and a sequence of pushing the brake pedal followed by setting the parking brake in order for video to work. I plan on trying to ground the parking brake first and see if that works though.
I haven’t had a chance to look at the junction box yet, but far as the wire in the junction box goes, do any of you recall what color it was? Thanks, D |
Save your self the hassle, buy this adapter, converts info from the can bus.
http://www.autosoundcentral.com/Peri..._p/chyah08.htm Used it on mine and worked great. Edit: My bad, didnt even think to see what year you had [duhhh] |
i second his Can Bus adapter...i used a cheapo, and it is crappy.
Thanks guys, but I have a 2005, the adapter looks llike it only works on 2006 models and beyond.-D
Find yourself an Alpine forum and research "hacking" the unit. I did it on my Pioneer and it required moving one wire on the main harness, and grounding it with the parking brake wire. This way your nav works while in motion, video if you so choose, and the wiring portion of your truck remains completely intact.
I asked a coworker who moonlights as a best buy installer, I'll respond back if he has a site to use... |
ok, i don't think a 2005 has can bus going to the radio.
you don't need VSS, i don't have it hooked up on mine (cheap adapter) you dont' want to put the ground to your parking brake, because then you can't have the wife put in addresses while you drive, and a LOT of times, you don't have a PLACE to stop. like if you are on the road, to meet at a Steak house, and the other couple calls, and wants chinese. it's just not functional. |
take the one for the parking brake and ground it, that way you can watch DVDs and adjust your NAV without it being in park. (you can put a switch on the parking brake lead, that way, if someone borrows your truck - they can't watch movies while driving) |
Yea, on my Avic all I had to do was switch two wires on the connector and ground them for the nav and dvd. Check radio forums. I actually got updated nav dvd's because someone posted .iso's for them.
Hello, Just wanted to follow up. Did you guys ever positively locate the backup wire that runs that the taillight? Which one is it? Thanks!
Originally Posted by hossola
(Post 3227498)
Originally Posted by enafzige
(Post 2460256)
--Eric
Originally Posted by 04ctd
(Post 2460259)
i found the reverse wire at the HUGE junction box, behind the front tire, underneath the drivers feet, under the vehicle.
you will see the huge terminals. Eric is right - be CAREFUL which wire, and double check it you can double check by having the MOTOR OFF and having someone put it in REVERSE, and hitting that wire with a test light. |
