How To: Front shock install
Old 07-24-2011, 06:03 AM
thor1721's Avatar
great post!! this saved me sometime trying to figure out what size sockets and wrench that i was going to need. Only a couple things i did different was i used a universal joint style adapter on the end on my 15mm to take the bracket nuts off worked good for me. Great job again Rock crawler
Old 07-27-2011, 04:04 PM
rockcrawler304's Avatar
Glad it helped! I can see where the u-joint would help. It can be tight in there.
Old 08-11-2011, 05:29 PM
spideygill's Avatar
Thanks for the post and for all the info. I think I will try and install mine this weekend. I just bought some KYB MonoMax shocks to help out the ride control.
Old 08-11-2011, 06:09 PM
Post up if you run into any issues! Or send me a PM I'll help ya that way to.
Old 08-18-2011, 03:33 PM
spideygill's Avatar
Haven't got'er done yet. Too many other things seem to come up. I'll try to get the rears on tonight if I can. The fronts will probably have to wait until next week...:-(
Old 09-02-2011, 05:54 PM
texasram2500's Avatar
I'm replacing my shocks. The back went on no problem. The front shocks I seem to be having trouble getting the top nut to come loose. The shock seems to be spinning with it. Any ideas?
Old 09-02-2011, 05:59 PM
If the shaft is spinning you will need to use a 3/8 (or 9mm) wrench on the top part and the other wrench to loosen the nut.
Do you have any air tools to use?
Old 09-02-2011, 10:34 PM
Bark's Avatar
rockcrawler, Great write up (I copied it back in Feb). Probably a dumb question, but are you having to jack up the truck at all when you change them?
Old 09-03-2011, 09:53 PM
Thanks!
I jacked up the front a few inches to take a little pressure off but it is really not needed.
Old 09-04-2011, 02:07 AM
spideygill's Avatar
I finally did all four today! It went pretty well, I didn't have to remove any batteries or airbox or tubes. I didn't jack it up at all and it was fine. It would have went faster, but I kept stopping for football breaks. ;-) I installed KYB Monomax and I really like the improved ride and control. Thanks RockCrawler!!
Old 09-04-2011, 05:46 PM
Bark's Avatar
Neat stuff. Thanks again.
Old 09-04-2011, 11:11 PM
Any time guys! Just glad it has helped a few so far
Old 09-05-2011, 07:33 AM
Thanks for the write up. I finally got all 4 of my shocks replaced. The rear I had done before and are very easy. The front kept giving me issues that were minor but I finally got them done after about 4 hours. Top nut was the hardest part to get off. I used vice grips on the shaft through the wheel well to get it to stop turning. Oh 30 minutes of the time I spent looking for the rubber spacer that I dropped into the engine block and it didn't fall through.
But its done....thanks again.
Old 09-17-2011, 06:10 PM
fishhog's Avatar
Excellent advice. Just installed Bilstein 5100's and went almost perfect.
Unless you count a broken socket and having to track down a breaker bar to get the #$^#! lower shock bolts loose
Old 09-17-2011, 08:16 PM
Great to hear.
Broken sockets are never fun!
Quick Reply: How To: Front shock install
