Highbeams stuck on.
Old Aug 15, 2014 | 10:46 AM
MPDiesel's Avatar
Thumbs down Highbeams stuck on.
Hey guys, chalk up another issue on my dodge..
My highbeams are stuck on all the time while in gear, regardless of the indicator or hitting the switch. They started doing this on the highway and if I played with the switch they would go back to low beams. Untill I hit a bump, then boom highbeams would stick on again. An now I can't even get it to switch back at all.
They are after market HID's.
Does this sound like a bigger issue? Or just a loose ground some where?
Thanks!
Old Aug 18, 2014 | 11:16 PM
applied_gravity's Avatar
ahhh, the infamous Multi Function Switch strikes again!
see shorts' very nice write up on how to sort it out - you'll be amazed what a cheap little bit of plastic and tin this thing is
https://www.dieseltruckresource.com/...l-t306312.html
and maybe do it before you're out in a sleet storm in a ski area pkg lot in wyoming, with lots of drunks wandering by offering less than useful advice...
Old Aug 19, 2014 | 12:17 AM
MPDiesel's Avatar
Actually we unplugged the MFS, lights were still acting up, seems to be the whole TIPM, under the fuse box is Edit the bed...
Old Aug 19, 2014 | 12:41 PM
MikeyB's Avatar
Did you check to see if the truck high beam circuit is driving the HID controller? Could be the HID controller is causing the issue.
Old Aug 19, 2014 | 05:39 PM
MPDiesel's Avatar
My ABS light and e brake light are going off and on intermittanly too. And I had voltage problems, got a new alternator and batteries. Took out the module and there are some signs of minor heat damage.
birdboy
Dec 12, 2018 09:02 PM
Nor_Cal_Angler
16
Nov 11, 2008 10:24 AM
Baja
Jan 29, 2008 08:17 PM
04ctd
Sep 14, 2004 04:43 PM
