greasing ball joints?
Old Feb 21, 2005 | 05:41 PM
Gunpowder's Avatar
Question greasing ball joints?
Has anyone tried to use a needle tip on your grease gun to lube the ball joints? By poking it through the rubber boot and greasing it that way? I was wondering if it would be effective at all, or just a waste of grease.
Old Feb 21, 2005 | 08:07 PM
Fronty Owner's Avatar
I would say its a waste of grease.
Nissan used 1/8" pipe plugs in place of a grease zerk ($.02 instead of $.04), most of us have replaced them.
Old Feb 21, 2005 | 09:03 PM
Raspy's Avatar
It has been done and I think it is a good idea. But with the early failure that some are reporting I wonder if it will do any good or if there is a weakness in the design. I haven't done mine yet but will soon. I got the needle at Pep Boys. Too bad these new trucks are not set up like the first gens with zerk fittings on everything.
Wetspirit
Old Feb 21, 2005 | 09:56 PM
Hemi Cat's Avatar
I think you can extend the service life of the joint by injecting grease into them. Works good on sealed bearings too.
Old Feb 23, 2005 | 12:10 PM
Peterbilt's Avatar
I am also considering trying to inject grease. When I had my '02 Ford FX it was the same siutation and many guys injected grease into the greese boots. Seemed to help. Fords had ball joint problems to. But you had to replace the whole A arm.
pete
Old Feb 23, 2005 | 05:13 PM
PZM123's Avatar
Well I'm thinking if you poke a hole to put grease in, then there's a hole for the grease to get pushed back out. Plus your making the joint more prone to the elements. I've put 125,000 miles on greaseless joints & bearing both without a hitch.
Old Feb 23, 2005 | 05:17 PM
Mike_Boutet's Avatar
Your better off drilling a hole and installing a zerk fitting, and then apply the grease. Doing it this way pushes lube through the joint and not just filling the boot.
Old Feb 23, 2005 | 10:04 PM
bhoeffner's Avatar
Injecting grease into the boot is not going to help the joint at all. the grease needs to be pushed through the ball joint sp that it actually lubracates the area where the ball and socket rub toghther.
Old Feb 23, 2005 | 10:51 PM
Hemi Cat's Avatar
Any amount of grease injected into a sealed joint is going to help. And besides, it will never hurt it. Yes a grease fitting on the bottom forcing grease thru the joint is best, but if it is a sealed joint the only way to put grease in it is with a needle. As far as the little hole goes, you put in more grease than will spill out.
Old Feb 24, 2005 | 06:13 AM
kingofdodge7131's Avatar
how soon are these going out?
Old Feb 24, 2005 | 12:27 PM
Peterbilt's Avatar
The Ford guys seal the hole with black RTV. I don't know if it seals well enough, but they say it definitely extends the life. These joints seem like a crap shoot; some get poor performance other great. So, far I have 27K and all is OK (at least today ). Decent roads.
Pete
Old Feb 24, 2005 | 12:39 PM
kry226's Avatar
Can this actually be done? Seems like this would be one of the more worthwhile mods we could do. Would only cost whatever the zerks cost. Anyone?
Old Feb 24, 2005 | 03:33 PM
Gunpowder's Avatar
Thanks for all the replies. I know that having a zerk would be far better, but can that be done without disasembly? The hole would have to go all the way through so that the grease could get to where it needed to go.
Reading these posts about ball joints, lift pumps, u-joints, etc. makes me think I need a spare parts cabinet in the back!
Old Feb 24, 2005 | 09:33 PM
I dont see how anything can be drilled and tapped without removal.
1. you gonna have to remove the shavings.
2. its a PITA to drill while laying on your back under your truck.
3. drilling is easy compared to taping.
Old Feb 24, 2005 | 11:23 PM
Haulin_in_Dixie's Avatar
mine have 320k on them and they are still tight. R/S wheel bearing is getting some play. Left side tierod end is trashed. The tierod has a zerk.
cmp truck
0
Jun 9, 2015 04:40 PM
Diesel_Power_2
16
Feb 28, 2011 10:00 AM
Roperteacher
Sep 22, 2010 05:04 PM
firebill1720
20
Mar 5, 2010 09:23 AM
Dynocon
Mar 5, 2005 06:24 PM
