Which fuse to pull so truck cant start?
Old May 17, 2007 | 08:35 PM
fbx22's Avatar
I know the time somebody tried to break into my ford ranger in 2000 I was very mad and felt violated. I had left the keys in it with the doors locked as usual since I was working Law enforcement duties at the time and if I had to get up at night in the dark it was easier to just jump in and take off without having to deal with keys. I just tapped the remote door opener and the door opened and I got in a went. Well this idiot broke off my window visor and messed up the seal prying with a hanger and pressing the door buttons that are on the arm rest. Little did he know that the door locks were re designed so that the doors only opened with keys, the handle, or the remote. They quickly gave up and moved 2 cars down from mine which was none other than a dodge ram and succeeded He made it about 5 blocks before he was stopped for driving without head lights
Old May 17, 2007 | 09:38 PM
dspencer's Avatar
Pull one of the turbo to intake hoses off. Then stick a tennis ball into the opening and put the hose back on. No way they will find that one.
Old May 19, 2007 | 09:32 PM
Bark's Avatar
CTD is depressing but is no doubt totally correct. These thiefs now days are pretty good But I do like fvx22s idea of a dummy fuse. It might slow down the casual thief or joy rider.
Old May 19, 2007 | 11:27 PM
CatDiesel_762's Avatar
Why not just pull both batteies ground cable and tuck or tape them up and out of the way or folded back onto the cable. That way you are not draining your batteries and they can not start the truck since the batteries are disconected. Not to metion it would look like the batteries are still there.
Another thing if you can, just remove the batteries while you store your truck. If you take away the power source then the truck will not start. The only draw back would be the ECM and stored codes or settings.
I will admit, if someone wants your truck they are going to get your truck and will know what kind of security system you have and how to overide it. Just like in the Nickolas Cages's Gone in Sixty Seconds movie.
Shawn
Old May 20, 2007 | 11:36 PM
Struggle's Avatar
If battery power was removed then no alarm would sound until they figure out it will not run?
I would rather have the alarm making some noise if it should get tripped.
Old May 21, 2007 | 06:58 AM
Tree DR's Avatar
The fuse idea is great. Instead of pulling the fuse or putting a bad one in the hole just snap one of the prongs off a good fuse and put it back in the hole. No thing to show why it won't start unless they pull the fuse. There's probably several fuses that would prevent starting so every thief is going to have to know all of them.
Old May 22, 2007 | 08:32 PM
dodgeduner's Avatar
QUOTE=coparam4x4;1510231]I am going to be leaving my truck in a not so good area and will not be able to watch it all the time. Which fuse should I pull so that if someone tries to steal it, it wont start (just one more preventative measure).[/QUOTE]
[B][SIZE="7"]Keep your truck out of mexico and you wont have to worry about it..
Old May 23, 2007 | 12:12 AM
Oilguy's Avatar
I have a friend that installed a security switch like you find in a door jam of a regular home security system and wired it to the ignition... the truck would only start if there was a magnet in the cup holder that the switch was in.... pretty brilliant idea.... He left his keys in the vehicle and put the magnet in the other cup holder >>> You just had to know what to do or you were not getting that thang!! It was a Ferd Exploder so I wouldn't want it but it was still a great security idea....
JARHEAD
May 6, 2012 06:30 PM
bigjohn92
Nov 25, 2010 01:32 PM
MikeThomas
Mar 19, 2007 11:54 AM
Evildiesel
Nov 18, 2005 04:12 PM
screaminbanana
19
May 3, 2005 11:21 AM
