Firestone ride-rites
Old Nov 25, 2007 | 06:42 PM
IL Ram's Avatar
Someone told me to use the dual air-rite kit vs. single kit because in hard cornering the air bags would try to equalize and actually try to throw you.
Anyone had this problem or know anything about it?
Old Nov 25, 2007 | 06:51 PM
scootertrash35's Avatar
i don't race mine at talladega so i've havent had any problems with single
Old Nov 25, 2007 | 08:21 PM
C Schomer's Avatar
No problem with single. I've hauled big loads of gravel and loaded it evenly - still no problem. I tried seperate lines at first and thought it was a PITA to keep them the same - even with no leaks. Craig
Old Nov 25, 2007 | 09:52 PM
IL Ram's Avatar
Thanks for the info!
Old Nov 25, 2007 | 09:55 PM
Roperteacher's Avatar
I have seperate lines and it is a little PITA to make sure they are the same but I have a digital gauge and it is real handy and I love the bags!!
Old Nov 26, 2007 | 07:16 AM
doug duncan's Avatar
using separate lines is so you can level the load out, it is no worse than filling up your tires
Old Nov 26, 2007 | 08:50 AM
CD in NM's Avatar
I have mine on separate lines so that I can level the load, not a problem airing them up individually. I installed them that way to prevent auto equalization from occuring. The bags will respond to shifting weight forces if they are not individually aired.
CD
Old Nov 26, 2007 | 10:47 AM
if it were a problem i think semi's would air each side seperatly,but they don't
Old Nov 26, 2007 | 01:00 PM
XLR8R's Avatar
We run separate air circuits for each bag - makes tuning easier, and allows the bags to perform an anti-roll function in the turns.
Old Nov 26, 2007 | 01:12 PM
separate is the best way to go
Old Nov 26, 2007 | 05:10 PM
bigjohn04's Avatar
Here's my $.02. If your going to be pulling a trailer go with a single, but if your hauling in the bed do separate to level the truck.
Old Nov 26, 2007 | 06:47 PM
Mr Bee's Avatar
If I make a suggestion that could make life very easy.
Run seperate lines to the 2 schrader valves used to to fill the air bags.
Just behind the valves area insert 2 "T"s one in each line and insert a small valve between the lines. Close the valve and you have individual side control. Open it and you equalize the sides.
Old Nov 26, 2007 | 08:57 PM
bob4x4's Avatar
Semi's don't generally do any quick transient manuevers,when they do caca happens
Bob
SIXSLUG
Apr 9, 2013 06:01 PM
Evil Genius
30
Oct 7, 2008 10:04 AM
SundayMoney
Sep 9, 2008 09:11 PM
Roperteacher
15
Sep 21, 2007 10:49 PM
glowball
May 1, 2004 10:46 PM
