drivers window goes down crooked.
when i try to open my drivers window it almost always goes down crooked. the glass toward the front of the truck goes down faster than the rear part, and of course it binds up. does the window track need to be lubed up with some silicone or is there some type of clip that broke that holds the window to the raising and lowering arm?
Window
I had the same problem and had it replaced under warranty.
I had the same problem on my 04 Dodge. You need to remove the door handle by taking the bolt out of the back of it and remove the screws holding the door panel and then it should just pick straight up off the door and unhook the wiring harness to the window and lock controls. I had to pull back some of the plastic inside to see the bottom of the window. Set the bottom of the window in the clip and roll the window back up and the window will set back down in place in the clip. Hope this helps you out.
thenrie
Sep 25, 2011 04:47 PM
converteddzlr
Jul 29, 2005 01:35 PM
