Door hinge groaning
Old May 26, 2011 | 06:39 PM
Mexstan's Avatar
Door hinge groaning
As long as I have owned my truck I have been fighting the problem of groaning and squealing from the spring loaded gizmo on each door hinge that holds the doors open. I have tried various kinds of lubricants and the noise stops for a month or two and then comes back. Have owned many kinds of vehicles and none have given me a problem like this one. All other vehicles need an oiling every year or so, but not the Ram.
Anybody have any suggestions as to what I can do to lubricate the roller and stop the groaning when the doors are opened?
Old May 26, 2011 | 07:48 PM
Mr Jerry's Avatar
I would use a spray of Moly-lube, It used to be sold at chrysler years ago, Its a white spray lube with molithium disulfate, good stuff.
Old May 28, 2011 | 06:32 AM
Dodgezilla's Avatar
Mine's the same way Stan. I haven't found a solution either except for getting in and out "Dukes of Hazzard" style. It's getting harder to do each year though....
Old May 28, 2011 | 07:41 AM
MikeyB's Avatar
I lube the heck out of mine with white lithium spray from Permatex at least once a year. Never been a problem.
MikeyB
Old May 28, 2011 | 01:44 PM
tryNto's Avatar
Like MikeyB said, White Lithium Spray, I do mine once every year.
Old May 28, 2011 | 03:21 PM
Jeff in TD's Avatar
That's what I use too. You might try hitting them with some sort of solvent (paint safe) and compressed air to clean them up before hitting them with lube. You might be able to remove some grit and grime and let the lube get in there better.
Old May 28, 2011 | 05:44 PM
1-2-3's Avatar
Just a plain ole guy
your problem is what your using. it may quiet it for some time but dirt and grit sticks to it and makes things worse and grinds your parts away. You need to flush all that mes away and start using a dry lube that wont collect the grit
Old May 28, 2011 | 05:50 PM
Mexstan's Avatar
Thanks for the replies so far.
There is no dirt around the door hinges or inside the doors as I keep them clean at all times. When I lube them I always wipe off the excess oil. When I spray new oil on the offending parts, the oil goes directly on to clean parts.
Old May 28, 2011 | 06:17 PM
Shorts's Avatar
I'm using Lucas white lithium grease. I actually just grabbed it in a hurry as it was the only thing on the shelf.
rhett1948
13
Mar 17, 2008 07:20 PM
Rattlerattle
Sep 10, 2006 09:53 PM
JoeDiesel
Dec 13, 2005 10:02 AM
Bobcat698
Apr 24, 2005 07:56 AM
wagontrain131
May 21, 2004 02:57 PM
