cold weather codes?
Old Sep 29, 2006 | 07:50 AM
Dan Marino's Avatar
cold weather codes?
Has any one ever had trouble with a code comming up in cold weather only? Last year when it was below 45 degrees I always had code 2127 hit. (Pedal validation switch or throttle position sensor) I said then that I thought it was cold weather related and talked to two different dodge dealers and they said it shouldnt happen just because of temperature being colder. Well...this morning in was in the low 40's - and low and behold - it coded 2127. It hasnt hit since back in march or april - so I gurantee its a cold weather issue. Anyone else have this code or any other code hit during colder weather only?
Old Sep 29, 2006 | 03:53 PM
coparam4x4's Avatar
Nope, just got back from utah. 25 was the low when I left that morning.
Old Sep 29, 2006 | 11:57 PM
pet05's Avatar
Can that sensor be removed and maybe some Electrical Grease might help it. Cold weather makes plastic, metal, etc, do strange things.
Old Sep 30, 2006 | 08:21 AM
Dan Marino's Avatar
Good question. Last year when I was talking with the dealers I asked where it was and they both said bring it in. I never had time and then warm weather hit and I never worried about it again. Anyone know where pedal validation switch or throttle position sensor is?
Old Sep 30, 2006 | 02:20 PM
handymantim's Avatar
You might try doing an "apps reset." It's free and easy to do.
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Kinda sounds like your apps (accelerator pedal position sensor) is just slightly out of range when the temps drop. The apps is on the top, front driver's side of the engine just above the injection pump. Mine is covered with black plastic. However, with luck the apps reset procedure will solve the problem and you won't even need to find the apps or mess with it directly.
sallyman1
Aug 26, 2008 06:20 PM
Dynocon
Jan 9, 2008 07:00 PM
mbenedict
Jul 21, 2007 09:19 PM
joel
Jan 22, 2005 08:59 PM
wings
Nov 8, 2004 05:32 PM
