box frame
Old May 6, 2009 | 09:13 PM
gunnie's Avatar
box frame
hey guys can anyone tell me what year dodge started using the same frame on a 2500 and 3500? I'm kinda in a spot and need to know for sure.
thanks, gunnie
Old May 7, 2009 | 09:08 PM
BIGROD's Avatar
I was told that in 1994 Dodge went to using 1 frame just different lengths, for all trucks. The 1/2 ton has the same frame as the 1 ton. From what I under stand the spring mounts in the rear are different and the front cross member.
Old May 7, 2009 | 09:51 PM
bob4x4's Avatar
Way off base...........although there was a light and heavy 1 ton.
Old May 7, 2009 | 10:11 PM
DMP's Avatar
DMP
The frames are different the one ton frame has a different part number then the three quarter and so on. If they were the same they would have the same number
Old May 8, 2009 | 07:59 AM
CTD NUT's Avatar
2500/3500 frames are the same on 2nd and 3rd gens. I suppose a hole could be in a different spot or not be drilled for contact overload stops or something...but for purposes of this discussion, they are the same.
1/2 ton frames on both gens are most certainly very different.
Old May 8, 2009 | 08:59 PM
gunnie's Avatar
on my '00 3/4 ton the frame is not boxed, this is why I ask the original question about third gen 3/4 and 1 ton frames if both are boxed and the only difference is a hole location or bracket then they will interchange correct?
powerrammaster
Jul 7, 2013 05:20 AM
Tyheethan
Feb 25, 2009 12:12 PM
gts95
Aug 27, 2007 10:13 AM
95black2615
Dec 20, 2006 06:37 PM
ptgarcia
Sep 12, 2006 06:04 PM
