Blower motor fix
Old Feb 28, 2014 | 11:59 AM
junebug95628's Avatar
Blower motor fix
I have had an intermittent blower motor for a few months and decided to give it a look see. I pulled the unit out, disassembled it then cleaned, lubed, reassembled and it works fan-tastic!
1- remove fan from under dash with 5/16 nut driver after disconnecting wire.
Bench fan motor - use really large socket to set fan in to help hold upright.
2- using small pick release tabs that hold wire blades in connector and push blade backwards using a flat blade screwdriver. They don't have to come all the way out yet, just released from retainer tabs is fine.
3- remove spring clip on squirrel cage and gently loosen with pry bar and remove cage.
4- remove two Phillips screws on too of motor housing. You will see 3 pins with spring retainers, these do not need to be removed.
5- fan motor is held in housing by 3 rubber isolator pads. GENTLY pry motor out of housing.
6- now we disassemble motor. Using small metal chisel straighten area of case where it has been peened over the top cover. You will see 4 cover tabs that the case has been peened over two edges. Don't cut out material with chie just straighten it and pry case apart.
7- once case is split you can pull out stator with brush assembly. There will be two indexed washers on the bottom shaft, note orientation for reassembly.
8- gently slide brush assembly off stator and inspect brushes for condition.
9- in my case, the contact point where the brushes rub was really dirty. I cleaned this area by chucking the stator in the drill press and used 500 grit paper to polish the copper. Blew everything out and washed the squirrel cage then...
10- reassemble in reverse order
Old Feb 28, 2014 | 12:05 PM
jhenson's Avatar
Thanks for the write-up. This should be beneficial to many folks on here.
Old Feb 28, 2014 | 08:27 PM
rockcrawler304's Avatar
Excellent!!! Thanks for sharing.
What exactly were your issues? Mine seems fine now but just wondering what to look for in the future.
Jim Lane
Apr 5, 2020 06:03 AM
Redlinear
Jan 4, 2013 09:16 AM
Rickcher
Jul 13, 2009 01:22 PM
tom.jelly
Nov 10, 2006 02:04 AM
