ball joint torque question
Old Jul 19, 2007 | 11:26 PM
57ringo's Avatar
Does anyone know the torque specs on the upper and lower nuts on the ***** joints for my 05 2500 4x4....in my signature.
Old Jul 20, 2007 | 09:33 AM
Lifted06's Avatar
From the Service manual:
INSTALLATION
1. Position the steering knuckle on the ball studs.
2. Install and tighten lower ball stud nut to 47 N·m (35 ft. lbs.) torque. Do not install cotter pin at this time.
3. Install and tighten upper ball stud nut to 94 N·m (70 ft. lbs.) torque. Advance nut to next slot to line up hole and
install new cotter pin.
4. Retorque lower ball stud nut to 190–217 N·m (140–160 ft. lbs.) torque. Advance nut to next slot to line up hole
and install new cotter pin.
5. Install the hub bearing (Refer to 2 - SUSPENSION/FRONT/HUB / BEARING - INSTALLATION).
6. Install tie-rod or drag link end onto the steering knuckle arm.
7. Install the ABS sensor wire and bracket to the knuckle. Refer to Brakes, for proper procedure
Old Jul 20, 2007 | 10:20 AM
57ringo's Avatar
Thanks for the info !!!
Old Jul 21, 2007 | 11:04 PM
57ringo's Avatar
Do you know what the torque specs for the four bolts connecting the front driveshaft to front axle are?
72dart
Jun 19, 2012 10:42 PM
Wulzcat
Dec 19, 2009 05:15 PM
wcbcruzer
22
Apr 30, 2008 06:58 PM
FDC
Jul 16, 2007 12:51 PM
Treangen
May 7, 2007 03:10 PM
