Ball joint help please reply
Old Oct 1, 2011 | 10:54 AM
M1AM14SPUR's Avatar
Question Ball joint help please reply
I think my ball joints might be going bad, but I am not sure. How can you check? Is it usually the upper or lower ball joints that go bad? Is this a DIY job or should I get my mechanic to do it? Thanks again.
Old Oct 1, 2011 | 07:09 PM
M1AM14SPUR's Avatar
No one? Really?
Old Oct 1, 2011 | 08:22 PM
Rob's Red Ram's Avatar
I had mine done by mechanic as I didnt have the time or tools to do it myself.It's quit a bit of work to do.While your at it if they need to be done ,do the axle u joints and hub bearings since it's all gonna be apart anyway.Either top or bottom can go bad.Do a search for ball joints tons of info on here.I used XRF upper and lowers seem very high quality and many on here use them.
Old Oct 2, 2011 | 01:32 AM
nickg's Avatar
jack up the truck, grap the top of the wheel and push/pull if it moves you need uppers, do same at bottom of wheel, then get a prybar put under the bottom of the wheel then lift up, I believe its max 60thou play, any more requires replacement.
to remove if you have never done it, might be a handful
you need to remove rotor/hub assy/axel just to acess the spindle and ball joints. there are tricks along the way to make it easier, but you will need some tooling and a ball joint press to make the job easier or in some cases even possible
Old Oct 2, 2011 | 06:38 AM
Sur5er's Avatar
X2, X3. I did XRFs with a standard ball joint tool and it was a royal PITA! Not the XRFs, just the job (I also did the hubs at the same time). The regular OTC ball joint tool throat is just a tad too shallow and you have to maneuver the tool, the adapters or make additional ones. If you've never done ball joints or used the ball joint tool, I strongly recommend you have it done by someone that knows what they are doing. One final caution if you decide to try it yourself:
DO NOT USE AIR TOOLS ON THE BALL JOINT TOOL.IF IT FAILS, YOU WILL EAT THE TOOL
72dart
Jun 19, 2012 10:42 PM
Wulzcat
Dec 19, 2009 05:15 PM
wcbcruzer
22
Apr 30, 2008 06:58 PM
FDC
Jul 16, 2007 12:51 PM
Treangen
May 7, 2007 03:10 PM
