Bad - Holes Frame complaint on Ram
Old Apr 3, 2004 | 07:33 AM
rubbert's Avatar
Have a guy I know who was grumbling about his last Dodge - Hauls big bales w/lift and said his frame folded! Said it was full of holes and Dodge would not warranty any problems if a lift-spike was added? I hope this is not true!
Old Apr 3, 2004 | 07:36 AM
spots's Avatar
Hmmmm if you overload anything it will fail. Time for someone to get a grip I think.
Old Apr 3, 2004 | 10:39 AM
ranchoazul's Avatar
The new ones (3rd gen) have a fully hydroformed frame. If you start drilling holes or welding on this frame, DC will not warranty it. The manufacturer who drilled or welded on your frame will be responsible for the repairs.
My 2 cents.
Old Apr 3, 2004 | 03:45 PM
spots's Avatar
My 2 cents.
http://www.dodgeram.info/tsb/2003/13-001-03.htm
DC allows welding and holes on the 3rd gens.
Old Apr 3, 2004 | 04:07 PM
ranchoazul's Avatar
And here is the note from the TSB.
NOTE: DAIMLERCHRYSLER CORPORATION DOES NOT RECOMMEND ANY MODIFICATIONS OR ALTERATIONS TO THE FRAME ASSEMBLY. MODIFICATIONS OR ALTERATIONS (I.E., HOLE DRILLING WELDING, ETC.) TO THE FRAME ASSEMBLY ARE THE RESPONSIBILITY OF THE PERSONS PERFORMING THESE MODIFICATIONS OR ALTERATIONS. ANYONE ALTERING THE FRAME MUST ASSURE COMPLETE RESPONSIBILITY FOR ASSEMBLY, PERFORMANCE RELIABILITY AND COMPLIANCE OF APPLICABLE FMSS REQUIREMENTS.
If you or an installer weld or drill in the frame, some one else will be responsible for the warranty besides DC.
Old Apr 3, 2004 | 04:41 PM
rlyoung's Avatar
ranchoazul,
In all fairness and to not cloud the issue of frame drilling / welding, I think you should have quoted the complete tsb. I believe it goes on to give pertinent details about the correct way to drill and weld the frame if necessary to do so.
The tsb merely states that DC cannot be held responsible, (which I think is obvious), but does not imply as many people think, that the frame cannot be drilled or welded.
1969mach1
Apr 5, 2007 07:47 PM
coolslice
Sep 7, 2004 09:33 PM
Crabjoe
Mar 13, 2004 10:23 AM
Rusty69
16
Jan 23, 2004 09:35 PM
Patrick Campbell
21
Sep 15, 2003 09:00 PM
