Aus. fuel tank - gravity feed - filter?
Old Sep 8, 2008 | 08:19 PM
beardedone's Avatar
I am getting a cross the box aux. fuel tank and will plumb it in a gravity feed manner. Should I put a filter in line or will it slow down the flow.
Old Sep 8, 2008 | 09:18 PM
carl48's Avatar
i use a 86377 carquest 2 micron filter , i had a pump hooked to it for a year before i tried gravity, it works perfect if you send me your email address i can send pix and the disconnected pump is in the background . i have a fitting on the bottom of my 100 gallon l tank connected to a sediment bowl . through the 86377 to the tank never fill the truck tank at the station that way all of the fuel in the truck tank has to go through the 2 micron filter
Old Sep 9, 2008 | 01:58 PM
Flopster843's Avatar
I had a filter installed with my aux tank on my old truck monted under the bed. The flow was to slow in the first place to notice if it slowed down any with the filter. However, with the filter installed, I can not drain the bottom 1.5 inches of fuel out of my tank. There simply isn't enough fuel weight left to push it through the filter. Just something to keep in mind.
welndmn
16
Mar 31, 2020 10:16 AM
pwrtripls1
40
Sep 24, 2008 02:27 PM
CrazyFloyd
Aug 13, 2007 02:41 PM
svanni
13
Sep 6, 2006 07:37 PM
deviousracing
May 19, 2005 03:35 PM
