Adding circuit to 'spare' fuse
Old Aug 24, 2006 | 06:42 PM
BigDiesels's Avatar
How do you go about adding a circuit to the fusebox under the hood, using one of the 'spare' fuses. Looks like everything runs off a common buss, then the big Deutsch style plugs distribute to the systems. Do you need to find the Deutsch plug, and then add the wire in the block (special tools required) or is there a simpler way?
Thanks in advance.
Old Aug 24, 2006 | 08:29 PM
gerry's Avatar
On my 05 there was on fuse space with no fuse in it markes spare.... I used an "add a Fuse" plugged in there and only put the fuse in for the added part. then I cut a small "U" shaped slot in the fuse box cover and installed the wire through a rubber gromet.. You can also put in the add a fuse in any spot of the fuse box (It's just a piggy backed fuse with a wire comming out of it..)
Gerry
Old Aug 26, 2006 | 02:36 PM
trander's Avatar
I used one of these, works great.
http://store.summitracing.com/partde...5&autoview=sku
iweb
Jun 14, 2015 07:30 AM
Joe Diesel
Nov 12, 2007 08:59 AM
Boatnik
Nov 6, 2007 07:52 PM
mazeeff
Jan 24, 2004 10:47 PM
