3G frame repair
Old Oct 25, 2003 | 12:35 AM
westcoaster's Avatar
3G frame repair
CAUTION: 1500 series Dodge Ram Trucks (2002 and
later) are not designed for snow plow equipment.
The front collision repair tips must not be installed
on any truck equipped with a snow plow, or even
intended to be equipped with a snow plow.
CAUTION: This procedure is designed to replace
the front frame rail tips that have been damaged in
the crush initiator zones. Prior to any cutting, the
vehicle must be mounted on the appropriate frame
repair equipment (“frame rack”), checked with three
dimensional measuring equipment, and the necessary
pull corrections made. If damage remains in
the frame beyond the area covered by this service
part after the pull, the frame must be replaced in its
entirety.
so I was reading through the maintaince manual for the third gen trucks. under tab 13: frames and bumpers, sub heading frames. There is a repair procedure for vehicles that have been involved in a collision and have had the front frame bent. To be brief... it involves cutting the frame at a specific point, installing a sleave on the inside of the frame and welding. The quotes above are cautionary notes that appear to limit the use of the vehicle that have had this procedure done to it.
now, If I am reading this correctly I think if I ever get into an accident I had better find some plow equipment to hang off the front of my truck, just to make sure I get what I had before...
The one disclaimer is the "light duty front frame rail tip replacement" Do you think they are talking 1500 trucks?? ??? :-[
roxxx
Nov 19, 2021 03:07 PM
Tyheethan
Feb 25, 2009 12:12 PM
gts95
Aug 27, 2007 10:13 AM
95black2615
Dec 20, 2006 06:37 PM
ptgarcia
Sep 12, 2006 06:04 PM
