35's with only a 2" level lift?
Old May 30, 2010 | 11:30 PM
blackram2500's Avatar
Is this possible? I plan on running OE replacement 17" black steelies, and Toyo MT 35 x 12.5, is a 2" leveling kit enough on a 3rd gen?
Old May 30, 2010 | 11:46 PM
JoshBrown's Avatar
Not a problem. If you are using a spacer to level it makes the ride harsher then stock, I have one. Some say it won't but I feel they are the same guys that put the square in the round hole is a child.
Old May 31, 2010 | 04:26 PM
IPDiesel's Avatar
toyo mt 35x12 on stock rims with no leveling kit is doable. there is the ever so slight rub from the tires on the inner control arm at full lock-but that is only when the tires are brand new. The rubbing goes away after a little tire where is done.
Old May 31, 2010 | 04:31 PM
05 dodge's Avatar
35's with 2in leveling kit is no problem. As you can see in photo.
Old May 31, 2010 | 04:34 PM
05 dodge's Avatar
35's with 2in leveling kit.
Old May 31, 2010 | 07:04 PM
Sweet, thanks! Decided to get the stockers powdercoated that way no guesswork with offset issues. How wide are those tires in the pic?
Old May 31, 2010 | 07:17 PM
05 dodge's Avatar
Thr tire size 35x12.50r, actual tread width is 10in.and no tire rub
jmccart
Feb 18, 2008 10:27 AM
jmccart
Dec 21, 2007 06:00 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
z-rider
Jun 19, 2007 05:15 PM
teckert
Jun 9, 2004 12:34 PM
