new truck question bout 6.7
All you need is the delete exhaust pipe and the programmer. You will get the best of all worlds - power, mpg, and peace of mind.
I run mine the same as lil' dog because I need to revert at certain times for smog. However, if I did not, it would delete everything in sight.
It is really a piece of cake. Even a cave man can do it!
Deleting is so easy, even Blake can write the tutorial!
mega is right though, all you need is a delete pipe and the smarty. Thats the extent of the hard parts. Follow the tutorial to the "T" and you will be fine.
If you want to monitor an Edge insight will do you fine for digital gauges. If you want analog, EGT, Boost and Tranny temp is what I recommend.
The JRME version has the capability of doing any and all styles of deletes, as well as adding HP.
http://www.madselectronics.com/SmartyJ67ME.html
Smarty Jr adds power in levels of 40, 70, and 100hp. It will increase milage on various settings when driven responsibly.
is there any reason a dpf delete pipe for me 2007.5 dodge 6.7 cant be made i have a friend that does exhausts for a living and just wanted to know if it can be done i thought mabe if i find or if possible make the piece that bolts together if anyone would know this forum would thanks ken
Flowpro is usually decent stuff, and I think Lary might even have that available in the DTR store.
Give him a shout and he will take care of what ever it is you need.
