New Gage set installed
Hey guys, need some input. I have just installed a set of gages in the process of getting my truck set up to tow my 5th wheel. My question is at what temp should I be getting worried about EGT. Also Trans temp what is the temp I need to be looking for an exit. I'm not versed that well about those things and diesels in general. This forum is where I've gotten most of my knowledge.
The truck is in my signature the camper's gross weight is 13900 and If I can help it I plan on keeping it below 13K if at all possible.
Thanks in advance for your input.
Now with the transmission oil temperature this depends on where the temperature probe is located. I have mine in the transmission oil pan and I am using a MAG-HYTEC AL pan that adds 2-1/2 quarts of oil capacity. My transmission oil temps run around 180F when towing and I have seen on occasion 200F but never over that with my set up.
Jim W.
Hey thanks for the reply Jim. Just in everyday driving I'm seeing EGT up to 550 600 and as low as 300. I have the trans temp installed in the test port as that is where the manufacture said install it. the trans temps today did,t get over 120. That is no load hwy and some in town driving.
Hope this helps.
Jim W.
I see around 600F when I am driving around town at 1600RPM"S in 4th gear. On the highway I can see up to 800f when not towing but it will drop back to 700F to 750F in 6th gear and 1500RPM's and under 10 PSI of boost.
My probe is in pre-turbo and between number 3 and 4 cylinders right around the Y in the exhaust manifold. See pic.
That is pretty much exactly where I have mine and I am seeing pretty much the same EGT's you do in these some conditions. I was wondering about the original poster's because they seemed so darn low.
brianh1
Mar 26, 2008 05:15 PM
West Coast
Dec 14, 2007 04:49 PM
tony597fitter
Mar 12, 2007 10:28 PM
