3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
egr still on over head consol
Old Sep 21, 2015 | 03:53 PM
popsday's Avatar
I had a egr delete done on my 07 6.7 every thing is fine but I don't know how to clear the over head consol any ideas would be welcome Thanks popday.
Old Sep 21, 2015 | 07:37 PM
xcc_rider's Avatar
What's the message on the ovhd display? When did it come on? Before or after the delete?
Did you use a tuner or just delete the egr system?
What code(s) are you showing?
Old Sep 22, 2015 | 01:01 PM
popsday's Avatar
egr still on
The check eng light was I don't remember the code, the ovr con. said the exhaust was full reg. required I did not remove it be for I had the egr delete done, I don't have a check engine lite just the over head still says exhaust is full, if I have the delete removed then remove it from the consol and then put the delete back in do you think that will solve my problem Thanks popsday.
Old Sep 23, 2015 | 10:15 PM
xcc_rider's Avatar
I'm still alittle confused. Did you delete the exhaust at the same time you deleted the egr or just the egr alone?
Is the stock exhaust still installed?
Did you use a tuner to delete the system(s)?
IF you used a tuner to delete both systems and you're still getting the dpf full message then I would question if you have a delete capable tune or tuner.
Old Sep 24, 2015 | 02:37 PM
popsday's Avatar
over head consol
Rider I had a complete done I have a straight pipe from the exhaust all the way back the up front stuff is gone and it has had a delete tune done on the computer the check eng lite is off but when I took it in for the delete the check eng lite was on and the over head consol said I my exhaust needed to be regenerated, every thing is fine with the truck except the consol still need to regenerate plus it says my exhaust is empty and I cant get rid of it do you have any ideas ? Thanks for the help popsday.
Old Sep 24, 2015 | 10:00 PM
xcc_rider's Avatar
I know with some tuners they recommend you to be code/message/problem free at the time of tuning due to this kind of problem.
The message may be locked in the pcm and may not go away. You can try returning it to stock, clearing codes (even if none are shown), and reloading your tune to see if it will clear. This isn't a sure thing but what I'd try to get rid of the message.
You can also try clearing the codes and just reloading the tune or whatever combinatin feels good to you. It may work, may just go away in time or stay forever. Its a crap shoot.
Old Sep 25, 2015 | 11:58 AM
mega-engr's Avatar
"California Style"
Good suggestions here. I would try these scenarios as well.
Old Sep 28, 2015 | 07:54 PM
popsday's Avatar
Rider it's an efilive tune and other's are having the same problem, efilive turners are working on the problem so they are aware of the problem I gess I will have to wait and see what happen's thanks for the help Popsday.
screamin01
Mar 2, 2009 09:43 AM
xzaq103
Dec 7, 2007 09:03 AM
scottsjeeprolet
Mar 20, 2007 12:34 PM
AmtrakConductor
Aug 15, 2004 06:08 PM
Desert Diesel
Feb 6, 2003 10:42 PM
