will smarty stack with edge??
Old Feb 15, 2008 | 11:00 PM
ihatesparkplugs's Avatar
will a smarty stack with a edge juice with attitude? That wat I can use the edge for gauges? if they will not stack what can i stack with a edge juice with attitude and get good gains?
Old Feb 15, 2008 | 11:06 PM
White97GTVert's Avatar
Not with and 04.5 or and 05. Maybe on an 06? Not sure I've read anybody trying it. 06 No longer has the datalink cable connection which was rumored to be the issue with the 04.5/05. With the 04.5/05 the edge makes no more power, no matter what setting it's on. Mine seemed to lose power. Didn't like the info it was getting from the computer that smarty had modified is what I heard.
Old Feb 16, 2008 | 03:37 AM
Megadeth's Avatar
It wont stack very well because Smarty and the Edge both do timing and duration.
if I were you i'd get a TS MP8 for pressure.
Old Feb 16, 2008 | 03:44 PM
omaharam's Avatar
Well, that's 1/2 right.
"if I were you i'd get a TS MP8 for pressure." < that part is good advise.
Old Feb 16, 2008 | 05:07 PM
The TS is good advise for sure. But you can definitely stack the Smarty and a duration+timing box. TST is a prime example. However you should have the adjustable TST box so that it doesn't add any timing over the Smarty, or use the TST timing and set Smarty for an even number (no timing added)
Old Feb 16, 2008 | 05:15 PM
dropped2500's Avatar
then why couldnt you run the juice and smarty on odd for no timing?
Old Feb 16, 2008 | 05:22 PM
There are quite a few posts on here why it doesnt work. The edge doesn't like what it sees coming from the datalink connector after Smarty has reprogrammed the ECM. Seems like its an 04.5/05 issue. I've seen people stack it with an 06 (no datalink cable anymore) and I think an 03 that worked.
No matter what you put the Edge to it doesn't add anymore power. My truck felt slower as soon as I turned the edge past 0 but others have reported it was same, just no additional power.
Topper
Mar 3, 2008 10:17 AM
Jordan5687
0
Jul 2, 2007 11:06 AM
whitestreak06
Jun 8, 2007 01:29 AM
VikingDiesel
Nov 15, 2006 12:24 AM
JIT
Oct 19, 2006 09:55 PM
