Wicked Diesel Arson kit
Can anyone tell me what this is and does. Does it help a close to stock truck. Is it similar to a DIY CP3 mod?
Well what i can tell you is that it helps the guy who starts to run agressive fueling boxes with bigger injectors. Keeps the rail pressure up. Its an upgrade to the cp3 injection pump. its a good starting spot for upgrades to the pump, its basically the "building block" to bigger pumps. Others im sure can explain it better than me, or have other insights.
I read somwhere that this alone can add 50-80hp. Is this correct?
I have one.
It is almost a stage one pump, not hard to do if you are somewhat mechanically inclined. The mod itself does not add any hp, (maybe 5-10) but it gives the potential for more fuel to make more HP. I am running ~150 hp sticks, and it supports me with my mods turned to kill with 26.5k down the track at WOT... I highly reccomend it. Shane is also good people to deal with. What else do you want to know? If you do decide to get it, PM me, and I will give you some tips that will help you out. |
Is this similar to the Floor it DIY CP3 upgrade or what parts do you get?
I also dealt with Shane and found him to be ANYTHING but honest in his business dealings....I would be VERY careful when dealing with him ;)
Most guys that get this mod quickly wish they had saved their money and put it toward a more substantial pump upgrade like you get from Floor It. |
Does this kit allow the pump to flow more fuel and/or does it increase the pressure to the injectors?
My FCA is going so I'm thinking of a kit like this to fix my problem. |
I just got one, not installed yet, but my thought process was to start with the arson 2 kit, and when i get injectors, upgrade to the full modded CP3 pump (as the Arson 2 parts are used on the full modded cp3 pump)...you sort of get a credit in lieu of paying full price....e.g. it's ok to do it in this sequence..you're not throwing your money away......and for stock injectors, i dont think a full modded cp3 is required, granted if i had unlimited funds, i'd spend the $1600 on the full modded pump, i dont, so $345 is much easier to handle
I talked to Shane at Wicked about the above..he was very helpful and seemed like good people to me. |
The Arson II is a stg 1 CP3, and a STG 2 just adds some porting for more plunger volume and flow.
If you wait a week or two, he's coming out with the arson 3 kit (right now its the arson 2). Its suppose to flow more and give an extra 20hp, and its going to be 50 more bucks, well worth it IMO. Also, if you get his Arson kit and eventually want a bigger CP3, like a stage 3, he subtracts the price of the Arson kit from the CP3, so you arent buying anything twice. And Shane at Wicked has awsome, customer service.
I talked to Shane at Wicked about the above..he was very helpful and seemed like good people to me.[/QUOTE]
X2 ..I have one on the way also. |
Originally Posted by Hintz
(Post 2349327)
If it's truely 20hp more flow for $50, guessing it's worth it. |
Originally Posted by jgiachino
(Post 2349391)
We'll that sucks, just got mine a week ago and sitting in a box in my garage....i emailed Shane to see if worth sending back and paying the extra $50....in the end i'm going to a stage 3 CP3....so not sure if it matters or not?
(Post 2349203)
(Post 2349085)
