Why can't I tell a difference between tow and Crazy Larry?
Well like the title says I cant tell a difference between tow, performance, and crazy larry. Ive got a power puck, quad boost fooler and obviously a bully dog. I towed 11k+ pounds up the mountains for hours yesterday and never even came close to haveing any egt issue's. The truck seems really tempermental, sometimes it will flat move and blow alot of smoke and 15 min of driving later I will only get a slight puff and she will be slower. I'm a little confused with all of of this any ideas?
Its the truck in my sig, 2.4.d CR and the puck was on 90. |
Sometimes there programming will stick on a certain level.
When I had my triple dog, I had lots of problems when I tried to use the boost fooler with it. Sometimes the truck would run great and other times it just plain sucked. Removed the boost fooler and all was fine; put it back on and problems came back. I have heard of a couple others having the same problems.
Originally Posted by 06CTDforAU
(Post 1965429)
Oh and I forgot to mention fuel is covered to I've got an airdog
Crazy Larry zip file
I upgraded my programmer and lost the original crazy larry that would flat haul butt . I got a new beta 2.4 and I too seem to have lost the crazy larry seat of the pants effect,and it is almost like the outlook does not change the settings even though I have it set to the proper truck.
I didn't think the crazzy larry worked on the 03 and 04's because they didn'y have the 3rd inj event
Originally Posted by blownsmoke2
(Post 1965697)
Originally Posted by freytes2004
(Post 1965534)
I have 2.27, 2.30, 2.38, and 2.41 and I uploaded them on a friends website if anyone wants them. Here.
Originally Posted by Jfaulkner
(Post 1966862)
Thanks alot bro now I can have my 2.3.0 back that gave the power fix and mpg I was craving.[laugh][laugh] |
Thanks! I also pulled my quad boost fooler off and I think she is running better.
Dont Forget Guys Once 2.4 Program Is Loaded You Have To Delete The Security Feature So You Can Go Back To The Older Programs..
Originally Posted by Rpainter
(Post 1967480)
How is that done? |
When I first downloaded crazy larry about a year ago, i had the same problem. they all seemed the same. i downloaded again and nothing. after a few attempts of putting it back into the truck. it just started working. Don't ask why, but if its working right you can even just rev to about 1500 and switch to extreme and the truck will rev higher by about 2-300 rpm.
