What is surge? sps 66 question?
Old Jan 8, 2006 | 02:07 AM
MoparRiggan's Avatar
What do you describe as surge?
I have an 05 ctd with a/t and cannot decide on sps 62 or sps 66.
what is this between 1700 and 1900 rpm? I really want more power but I also want drivability.
Old Jan 12, 2006 | 09:14 PM
Patriot_RAM's Avatar
I'll try to answer this one...
I kind of understand what turbo surge is, but I'm not sure that I understand it well enough to explain it. Basically, (especially under a load at mid-rpm and mid-boost), the pressure starts fluctuating. For example, my boost pressure gauge will bounce between 20 and 40 psi. I really do mean "bounce", as does the truck. If I keep the power settings lower, it isn't much of a problem. If you're towing, it will be more of a problem -- I don't tow. By the way, I have the 6sp and SPS66.
I hear that with your stack, the 66 should push around 60psi and the 62 I think about 50 or so. The 62 is more drivable, but the 66 will give you more air volume, thus a bit more power.
I love the SPS66 and don't regret it a bit. If I towed, I would have definately gone with the 62.
Hope this helps!
Syndicate
Feb 12, 2006 01:55 AM
napa 600
Dec 17, 2005 01:34 PM
MoparRiggan
Oct 13, 2005 06:13 PM
RamWheelsBy4
Aug 24, 2005 05:50 PM
mattymac
Jul 22, 2005 06:24 PM
