what to feed CP3?
what to feed CP3?
looking to add aux. pump to cp3. no guage yet....soon. fass pump,dd pump.?what have u guys had luck with? also if the stock lift pump quits will the aux. pump pull through it? any info would be great.
You will see various pumps being used in signatures, Carter, Holly, FASS, Air Dog, Aeroquip, etc.. They all seem to have their occasional bugs. I like my 95gph FASS. I didn't like the 150gph FASS.
I don't think you will be able to suck through a failed stock lift pump. Others can probably confirm yes or no.
An option....the FASS and Air Dog comes with all new fuel line. You can plumb it directly in to your CP3 and leave the factory fuel lines and pump in their place. Just plug the ends. If you ever have a pump failure, the factory pump can be hooked back up in 20 minutes or less on the side of the road. Not that I would look forward to doing that, but if my FASS ever died and I was stuck somewhere, I would have the option.
fuel to CP3
I am in the process of finishing my half scotty half custom installation. New 1/2 line (bulkhead fitting in tank) to a high flow holley filter (60 micron screen) to the new holley gerotor 12-150 pump. Also the system will feature a check valve , in case of pump failure the CP3 will be able to pull fuel through the bypass check valve. The front end is all Scotty smart fuel. doug
streetsmoker
36
Feb 7, 2008 07:16 PM
powerstrokin03
Feb 15, 2007 04:29 PM
deezilpwr
Oct 22, 2006 12:45 AM
Superduty
80
Jun 1, 2006 09:38 AM
