What To Do FIRST ! (06)
Just got a 2006, 2500, 4x4, Quad-cab. 156Kmi (new Toyo tires)
Truck runs/looks great. Carfax says it had routine maintenance (one-owner); born date: July 2005. Here's what I'm doing FIRST...basic PM... --Flush/fill transmission (synthetic) --Oil change (I've always used "Mystic 15/40 syn-blend" with no issues; KnN filter...I just like the little built-on 'nut') --Fuel filter (WIX) --Differential fluid change (planning to use the 'thicker' fluid...southTexas...) --Coolant flush/fill SECOND projects (random order; please rank them for me) --Still has the stock air filter...thinking to change to one of the "open air" set-ups.... y/n? --Fuel "pusher" ...not sure if the 06's need an aftermarket pump (I liked it on my 2001)...y/n? Overhead computer reads 18.1 mpg...just on my #1 tank full, so not sure that'll be accurate on paper yet Any "watch-out for" xxxx or "be sure to check" yyyy items yall suggest? Any typical "leaks" here or there to check? No obvious drips/drops underneath at this time... Belts? Pumps? Additives? Thanks! USAF (Ret'd); 06, Laramie, 4x4, Quad; all stock (except Toyo A/T tires) |
I would do the FASS system first.
AS far as the air box, I actually went back to the stock air box. There are alot of discussion on this subject. I actually did a version of the home depot mod. I would check ball joints and steering components for wear..ie balljoints,wheel bearings, steering box etc. |
Originally Posted by ftltmp
(Post 3305810)
I would do the FASS system first..... a version of the home depot mod.......ball joints and steering components ....
Home Depot mod: I'll have to look up that one... Oh yeah, forgot the front-end components; tks! Also, just thought of the U-JOINTS...not sure when/ever they have been changed. I did crawl under and look. Although the previous owner (1) was from S.Texas, the Carfax did give indication of some travel/maintenance in Colorado. When I crawled under, I thought the underside showed signs of having been in snow area (salt). [yuk] Thanks! |
Stick with a paper filter. Get a Smarty Jr. They are inexpensive. You'll be able to read and clear codes.
Originally Posted by CRToney
(Post 3305817)
Stick with a paper filter. Get a Smarty Jr. They are inexpensive. .....
Picked up a 'Bluetooth' OBD code reader ("Kiwi3" by PLX)...pretty nice...allows me to read/clear codes as well as monitor systems. But will look at the SmartyJr. Paper filter... preference? any I should avoid? recommendation? Thanks!! |
Unless you know when the water pump was last replaced I'd definitely do that as preventative maintenance.
I've had my 06 since new in Feb of 06 with now 159K miles. It has been a great truck and no fuel system problems. |
Originally Posted by ssandlin
(Post 3305846)
Unless you know when the water pump was last replaced I'd definitely do that as preventative maintenance.....
Originally Posted by danalex
(Post 3305809)
Truck runs/looks great. Carfax says it had routine maintenance (one-owner); born date: July 2005. Here's what I'm doing FIRST...basic PM... --Flush/fill transmission (synthetic) --Oil change (I've always used "Mystic 15/40 syn-blend" with no issues; KnN filter...I just like the little built-on 'nut') --Fuel filter (WIX) --Differential fluid change (planning to use the 'thicker' fluid...southTexas...) --Coolant flush/fill SECOND projects (random order; please rank them for me) --Still has the stock air filter...thinking to change to one of the "open air" set-ups.... y/n? --Fuel "pusher" ...not sure if the 06's need an aftermarket pump (I liked it on my 2001)...y/n? Overhead computer reads 18.1 mpg...just on my #1 tank full, so not sure that'll be accurate on paper yet Any "watch-out for" xxxx or "be sure to check" yyyy items yall suggest? Any typical "leaks" here or there to check? No obvious drips/drops underneath at this time... Belts? Pumps? Additives? Thanks! USAF (Ret'd); 06, Laramie, 4x4, Quad; all stock (except Toyo A/T tires) Aux. fuel filteration is a must. Stock is not enough, i added a filter head and a 2~ micron just after my oem filter. The oem replacement is= Baldwin pf7977 [drop in]/ the aux filter is= Donaldson p551313 {others may have other favorites, but this will get you in the right direction!] Be carefull with K&N, lots of warnings on that , after asking i used the AFE Progard7 drop in air filter in my stock box. I added the Cool Hose and the DIY cold air intake. The oem in-tank lift pump is quiet, supports 500~hp, i would leave it.... Gauges, lots of them ;) just me, but i like to know whats going on..Electronic moniters are nice, I have the Smarty Touch, this gives me tuning and gauges... I can even get custom tuning =UDC Pro :cool: |
You have an 06, EFI Live is an option for custom tuning, often recommended...
Originally Posted by organicfarmer
(Post 3305876)
Hello! Enjoy your Ram!
Aux. fuel filteration is a must. ..... i added a filter head and a 2~ micron just after my oem filter. .... The oem in-tank lift pump is quiet, supports 500~hp, i would leave it.... : 1) Filter head just after the oem---where is the kit/reference for adding another filter head? ...so, the stock filtration is insufficient? 2) OEM lift pump in tank... so, no need for a "pusher" pump in the 2006s? --that's good to know! Gauges...eventually. |
(Post 3305877)
You have an 06, EFI Live is an option.....
danalex:
First of all,.....thanks for your service to our country!:thumbsup: I am an Air Force veteran too having served during the Vietnam years. I was a 46250,... Weapons Maintenance and worked on the AC-130 Gunships, F-4's, B-52's. You have already gotten alot of good advice from our members here. I would add that if you are going to modify the truck much over about 50-75 H.P. you are going to have to upgrade the transmission. If you go above those numbers, at least go with a triple-disc converter, better valve body, increased clutches in the OD and raise the line pressure. Unfortunately, the stock Dodge 48RE torque converters are very weak with their one single-disc. Other members already mentioned the gauges and I would recommend a pyrometer, boost and fuel pressure at the very least. If you are towing, a transmission temp gauge is also good to have. Take care and good luck! -------- John_P |
(Post 3305924)
Thanks!
1) Filter head just after the oem---where is the kit/reference for adding another filter head? ...so, the stock filtration is insufficient? 2) OEM lift pump in tank... so, no need for a "pusher" pump in the 2006s? --that's good to know! Gauges...eventually. I bought a wix filter head from amazon; ill look for the part # The oem pump is a 'push' pump I'm at 400rwhp and lp psi never drops. It is a fact that oem fuel filteration isnt enough with the common rail injectors. |
Originally Posted by John_P
(Post 3305926)
danalex:
You have already gotten alot of good advice from our members here. I would add that if you are going to modify the truck much over about 50-75 H.P. you are going to have to upgrade the transmission. If you go above those numbers, at least go with a triple-disc converter, better valve body, increased clutches in the OD and raise the line pressure. Unfortunately, the stock Dodge 48RE torque converters are very weak with their one single-disc. Other members already mentioned the gauges and I would recommend a pyrometer, boost and fuel pressure at the very least. If you are towing, a transmission temp gauge is also good to have. John_P I have the triple disc TC; i kinda wish i had a singal disc so it dosnt lock so hard, i still have the stock input shaft; i feel the triple disc should have the HD input... A shift kit with a good single disc low stall TC [Goerend] should be ok if trans pressure is high enough and HP isnt wild . Driver needs self control!! [redface] A low stall TC makes these trans a lot better for DD and towing! Not arguing with you John; just throwing my 2$ [duhhh] |
