Water/Meth VS. Nitrous
Old Jun 18, 2007 | 09:20 PM
SmokinDodge12V's Avatar
How about running both.
Old Jun 19, 2007 | 02:28 AM
RAT_03's Avatar
DTR's "Secret Agent"
So n2o is the way to really go it seems like
Old Jun 19, 2007 | 07:37 AM
trik396's Avatar
My opinion is that meth adds timing and if you've got alot of timing already, something can go pop (headgasket). If you need egt reduction just shoot the water. If your egt's still get out of hand you're probably WAY overfueled and/or need a bigger turbo anyway. Nothing is a perfect fix. I'm going to shoot water.
Old Jun 19, 2007 | 07:53 AM
dzlfarmboy's Avatar
I would just get water, nitrous gets real expensive filling them bottles and i would'nt wanna be spraying hooked to a sled all them time. No doubt you'll get alot more power out of it.I have spray but the next time i pull probably wont be using, cause i will deffenitly break something at that level, already snaped 2 D70 pinions at 550hp
Old Jun 19, 2007 | 08:40 AM
Coal Train's Avatar
I'm not scared about breaking stuff, thats part of it. If I was going to use a 100hp shot where would be the best place to put it at?
Old Jun 19, 2007 | 08:47 AM
trik396's Avatar
There's really no such thing as a 100hp shot when it comes to diesel. You can use Xnumber jet and make no horsepower improvement if you have no extra fuel. And you can make 150hp using X-number jet if you've got the fuel to burn.
Old Jun 19, 2007 | 10:47 AM
abc4yew's Avatar
If I was picking one spot to inject nitrous....three is the perfect setup.....it would be just before the intercooler. Putting it in there maximizes the cooling effect of the nitrous, makes the intercooler work way more efficiently and still provides the same amount of extra oxygen as flowing it into the intake manifold/horn. ks
Old Jun 19, 2007 | 04:26 PM
Coal Train's Avatar
So three spots to inject nitrous would be intercooler, intake and before the turbo??
Old Jun 19, 2007 | 04:27 PM
Coal Train's Avatar
Also what size jets do you guys use?
Old Jun 20, 2007 | 07:25 AM
Coal Train's Avatar
What about running nitrous with stock injectors, big risk???
Old Jun 20, 2007 | 09:00 AM
CamperAndy's Avatar
Methanol is fuel, not timing in the traditional sense but it can make a small difference in the ignition point on the compression stroke (sooner then #2 alone). Water will add mass and cooling effect and will will also affect the ignition point on the compression stroke (later then #2 alone). So the correct blend of water/methanol will have a neutral effect on the ignition point, will add mass for a given air flow, will add fuel and will reduce temperatures.
Old Jun 20, 2007 | 09:05 AM
trik396's Avatar
While that sounds good, I have to say that most headgasket problems I've heard about deal with meth and water. Never heard of problems shooting just water.
Ram_SRT-10
21
Aug 15, 2007 08:56 AM
Coal Train
Competition / Pulls / OffRoad
22
Jun 19, 2007 10:00 AM
3500lly
Feb 6, 2007 11:07 PM
chw
13
Dec 23, 2006 06:08 PM
red12valve
20
May 21, 2006 03:35 AM
