Walbro Diagram & Notes
Stacked97,
Thanks for the input. But I was still concerned about the turbo timer, so I pulled the Edge J/A installation manuals for comparision (04.5-05 vs 2006). I'm assuming that the LP wire you're referring to is one of the yellow wires connected to either fuse #28 or 35.
My 2006 Edge J/A does not have that connection. Instead, my connections were made somewhere up under the ignition switch on the steering column.
I don't know if that matters.
His turbo timer on his Edge still works fine. Im not sure if just a keyed hot will keep the truck running when it goes into turbo timer mode.
done...only took 5 hours to write it all up
https://www.dieseltruckresource.com/...d.php?t=156619
F. Flack
Mar 11, 2005 11:02 AM
