Variable Geometry Turbo??
Old Feb 10, 2007 | 10:04 AM
t-boe's Avatar
Can you even get these on the aftermarket for our trucks? Not the MST just regular VGT.
Old Feb 10, 2007 | 10:23 AM
acook's Avatar
Not that i know of. I dont really even see much of a benefit.
Old Feb 10, 2007 | 10:28 AM
t-boe's Avatar
Benefits of both a big and small turbos. Quick spool down low, large amounts of air up high. I figure that's why the 6.7 got it.
acook's Avatar
the 6.0 had them and they were dogs to spool up. If you want the beneifits of a big and small turbo get a big turbo and a small turbo and make a compound setup.
Old Feb 10, 2007 | 11:05 AM
Arkapigdiesel's Avatar
Not to mention that the vanes on the Garrett 6.0 PSD turbo were notorious for sticking and causing overboost and blown off boots.
I agree....get a small turbo feeding into the larger one
Old Feb 10, 2007 | 12:56 PM
XLR8R's Avatar
Guys, the VGT on the 6.7 is supposed to have been developed by Cummins just for their new engine... it's a Variable Geometry Turbo - the inlet nozzle slides back and forth, the vanes are stationary (except when they're rotating! )
Old Feb 10, 2007 | 01:19 PM
abc4yew's Avatar
The VGT on the 6.7 is still only designed for 325hp... To make big power you need the VGT off an ISX....I'm dumbfounded that one of the electronic gurus....Quad or otherwise haven't made a controller to control the V and marketed the turbos with a T6 manifold.....I think you'd sell a few.....2000ft-lb of torque.....it is a nice big turbo with low maintenance. The MST is the only one being marketed so far.....Mad Dog Madden is having one on the top of his Aurora twins. KS
Old Feb 10, 2007 | 02:18 PM
acook's Avatar
Yeah but as youll notice their are no MST's, theve been braging about that for so long its amazing, try and order one if you want, see what they say.
Old Feb 10, 2007 | 02:22 PM
NB64's Avatar
According to The Dodge web site the 07 non commercials will have 350HP and 650 torque. Did they remove the VGt from them? If not they must be rated for more than 325hp, I should think.
Old Feb 10, 2007 | 02:37 PM
XLR8R's Avatar
AFAIK, all 6.7Ls have both the VGT and integral exhaust brake.
Old Feb 10, 2007 | 03:33 PM
abc4yew's Avatar
Is the integral exhaust brake just the turbo closed down? and 325 or 350hp at 610 or 650 isn't 2000ft-lb.
Old Feb 10, 2007 | 05:29 PM
signature600's Avatar
Probably is just the smallest it can get.
Chris
Old Feb 10, 2007 | 07:25 PM
Smkndzl's Avatar
ABC, the exhaust brake on the 6.7 is just a calibration change if it is equipped with a VGTurbo. nothing else was installed.
Old Feb 10, 2007 | 08:08 PM
XLR8R's Avatar
If the VGT doesn't incorporate an actual exhaust brake, but relies on the sliding nozzle for engine braking - how well can that work?
Old Feb 10, 2007 | 10:39 PM
acook's Avatar
They tune alot of the 6.0's like this, so when you let off the throttle the vanes stick open. Ive tried it and it doest seem to work to bad but not near the way a real exhaust brake works.
