Valve Spring?
Old Jan 18, 2010 | 04:20 PM
Diesel87's Avatar
Valve Spring?
In the near future I will be installing twins, injectors, and an arson kit. When I do the injectors, I am going to install head studs while I am in there. Should I install valve springs? What are the pros and cons of installing valve springs? What brand is the best, and what weight? Thanks!
Old Jan 18, 2010 | 06:27 PM
Spooler's Avatar
Yes, I would install valve springs while you are at it especially with twins. What brand is best, that's in the eye of the beholder. You will need the springs for the higher boost levels. Personally, I like F1 springs. I am in the less is more crowd, but to each his own. Whatever springs you get, match it with the venders cam. Keep them together from the same vender.
Old Jan 18, 2010 | 10:12 PM
Diesel87's Avatar
I won't be doing a cam now anyway, but maybe down the road. I know Hamilton valve springs are 110lb springs, are the F1 springs 110lb or something different? Also how difficult is a valve spring install?
Old Jan 18, 2010 | 10:25 PM
madhat's Avatar
Administrator/Jarhead
Yes. Had I known then what I know now, I would have spend the extra $ to put springs in while I had everything apart.
Old Jan 19, 2010 | 09:51 AM
rogers259's Avatar
Cam can be done later on down the road if you want. I think what Spooler was getting at is if you get F-1 Springs get a F-1 cam or if you go with Hamilton springs get a Hamilton cam...when/if you decide to upgrade the cam.
I'm with Mark on this one...I should have had the Studs and Springs all done when I had the injectors out. Would have made life easier in the long run.
Old Jan 19, 2010 | 04:22 PM
Diesel87's Avatar
Thanks for your input guys. Looks like I am getting some valve springs. Sweet another $500!
BurrisWill
Jan 25, 2009 08:23 PM
DNRCustoms
Nov 24, 2008 09:30 PM
WhoCares79
Jun 3, 2008 11:45 AM
flynhigh205
Feb 26, 2008 10:33 AM
fishin fever
Mar 13, 2006 06:46 PM
