Turbo Suggestions.....
https://www.dieseltruckresource.com/...=228672&page=2
I've been very happy with the HTB2 turbo in my sig. I do a lot of towing, so I wanted a turbo with absolutely NO surging, no matter how heavy I am pulling. Spool time is identical to the stocker but the mid and upper range power is noticeably higher, even with stock fueling.
With my "hot" Juice on level "5" (+150hp - 400 lb-ft torque) the stocker would spike 43-44 lbs of boost, but the power was flat and the EGT's would be 1400 before I even reached 6th gear. With the HTB2, The turbo pulls hard all the way to red-line and I'm at my red-line in 6th gear before EGT's hit 1450 unloaded.
Best thing is, it was a drop-in install and was even able to keep my turbo-mount Jake Brake, which was one of the top criteria in choosing this turbo.
What are the specs of the BD Special, compared to the BD Single?
I know the stock HE341 is:
54/58/9cm
I was thinking about swapping in a 04.5-07 HE351:
60/60/9cm
But, I think an aftermarket turbo would still be best.....just have to weigh the price of the $1300-$2000 turbo compared to finding a good HE351 for
$300-$400
54/58/9cm
60/60/9cm
$300-$400
54/58/9cm
60/60/9cm
$300-$400
54/58/9cm
60/60/9cm
$300-$400
BD Special= 64/71/14
BD Single= 57/65/14
I've had my 62/65/13ss installed for a few weeks now....absolutely wonderful...very close to stock spool, fast boost to max psi, pulls harder...max of 1350* at the track in the 1/4 mile (to 100mph)....it does smoke more, granted i'm running either beta 4.4 lvl 9 or tnt lvl 7....and it's already 85* in phoenix....
Would get the same turbo all over again.....and it can grow with my needs weather it's upgrade to a 64 housing or use on top with twins.....
Ordered an adjustable boost elbow so i can easily set max boost a little higher...it's maxing at 40psi right now...probably change it to 42/43psi....
Go for it....good stuff.
What brand is your 62/65/13ss?
I've had my 62/65/13ss on for a year now, & I'm running TNT SW9 all the time. Even hauling my slide in camper I have no EGT problems unless I punch it on a 8% grade. I've hit 1560* once for a couple seconds. Passing a granola cruncher doing 45 in a 60 zone. The look on her face was priceless!
I think it's the best compromise for air/smoke/power you can get without going twins. And it will be good for that too someday.
So, how do I know if I have enough fueling?
I have my Smarty SR set on #7 and recently installed an Air Dog 150.
I 'might' be looking into an Arson II or the "Bag of Parts", but not sure yet.
After the turbo I do not plan on installing anything else for a while, performance-wise (like injectors, CP3s, etc)....
