Truck running bad. HELP!!!
Old Jul 18, 2008 | 10:48 PM
blwnsmke's Avatar
Originally Posted by rip 112
Clear the codes, apply dielectric grease to all the connections, and disconnect the batteries overnite. My truck idled very rough on occaision and what do you know a week later the RP gauge dies on me. I think it could be the culprit on code trippers, just being on once is enough.
My quad gauge works fine. I don't think it caused it since it does it even with it unplugged right?
Old Jul 18, 2008 | 10:51 PM
rip 112's Avatar
I suppose. I had the same problems as you, and it runs fine now that the RP is dead. But in your case it couldv'e damaged the sensor. These quad gauges are junk, I hate to say because I am a quad fan, just wish this product would have been better designed. Hopefully it is just a simple problem that can be fixed.
Old Jul 18, 2008 | 10:53 PM
blwnsmke's Avatar
Do you think that gauge could of caused my sensor to go bad? My RP gauge is working fine still.. I have been noticed some RP fluctuation for about the past month. Like 4k under wot or 1/2 throttle.. Maybe the sensor been going out??
Old Jul 18, 2008 | 10:58 PM
rip 112's Avatar
Yeah probably. being its an 04 that could always become an issue. Didn't you mention something about a TST or was I trippin? If you are returned to stock and still see the problems then thats probably the case.
Old Jul 18, 2008 | 11:01 PM
blwnsmke's Avatar
I have tst too but thats not hooked into my rail sensor.. I just don't understand why the RP gauge would smoke the sensor. It does it whether the gauge is hooked up or not and the gauge works perfectly fine..
Old Jul 18, 2008 | 11:02 PM
blwnsmke's Avatar
if it still acts like that with the quad rail gauge unplugged then it's either the fuel pressure sensor or a shorted wire..........that's my guess anyway.....first measure voltage.. you need to have 4.5-5.5 volts when measuring voltage on the supply and return circuits of the rail sensor plug(while unplugged from the sensor)...if you do clear the code plug the harness back into the sensor...then turn the ignition on...and go out and unplug the harness again....if the code comes right back it's the FP sensor......clear as MUD?????
Little confused on this. If the sensor was good or bad wouldn't it trip a code no matter what if you unplugged it??? Get a voltmeter and put it on which setting? Im not electrical guru by any means.. Will it stop at 4.5-5.5 volts?
Old Jul 18, 2008 | 11:04 PM
rip 112's Avatar
Have you checked all of the pins in the plugs to make sure they haven't slid over or disappeared, make sure they are making their contacts when you plug them in. As far as the RP gauge goes, seems like the wiring isn't the best and causes some voltage fluctuations. Not saying it does, but the thought is in my head.
Old Jul 18, 2008 | 11:12 PM
06RAM2500's Avatar
Unplugging it trips a P0193-Fuel Rail Pressure Circuit High.
Old Jul 18, 2008 | 11:14 PM
blwnsmke's Avatar
The RP gauge was my first guess to. But when I unplugged it and cleared the code and the truck did it again!! Now with everything on stock and the RP gauge unhooked I crank the truck up and it will idle now but rattles REALLY BAD like a 12v!! I don't think its the gauge. I think the sensor maybe we bad. I have had some bad rp fluctuations for a little while now. Like you could feel the whole truck lose some power and then pick back up when it did it.. Now this happen today.. I just need to know how to for sure figure out if its the sensor and which one..
Old Jul 18, 2008 | 11:15 PM
blwnsmke's Avatar
Oh.. Well mines pulling a too low code. I have tried cranking the truck up with both fca unplugged and then I also tried it with the rail sensor unplugged. Both times the truck ran bad and idled bad like a 12v
Old Jul 18, 2008 | 11:27 PM
06RAM2500's Avatar
The FCA controls how much fuel goes into the CP3 before it goes into the injectors. It might be the problem.
Old Jul 18, 2008 | 11:30 PM
blwnsmke's Avatar
So is there any definite way to tell if its whats bad or the rail sensor??
Old Jul 18, 2008 | 11:46 PM
mudder500's Avatar
My tuck did the same thing too. It was faulty wireing on my quad tow module. I took care of it with a hammer though.
Old Jul 19, 2008 | 12:03 AM
53 willys's Avatar
yeah you need to check it with a meter like I posted above......cars/trucks are DC volts.
RP sensor is still my vote.......
Old Jul 19, 2008 | 12:04 AM
blwnsmke's Avatar
Well I don't think its my quad RP gauge because
1. I have had it on there for about 2 months and no problems at all.
2. The truck started doing this today so I unplugged the gauge all the way and cleared the code and the truck still does it. So I don't really think its the gauge that did it since the truck does it with it unhooked.
I know the gauges were known to trip codes. BUT has a quad rp gauge every actually made a Rail Sensor go bad?? Or do they usually just trip codes and then unhook them and its fine??
