Transmission Temp Gauge installation
Old Aug 18, 2004 | 09:51 AM
MPowell800's Avatar
I'm not sure if I put the sending unit for the Transmission Temp Gauge in the correct place.
I have a 2004 with the 6speed manual transmission.
I couldn't find anywhere to mount that sending unit --except for in the back of the transfer case --I mounted it in the upper plug (maybe the fill plug). I just don't think that this is correct.
Going down the highway today (unloaded) at 70mph it finally got to 140degrees.
Is there a better place to mount the sending unit to get a more accurate temp reading?
Thanks
Mike
Old Aug 18, 2004 | 10:20 PM
Big Bob's Avatar
The tranny temp probe should go into the line that goes TO the tranny cooler, not the return line.
Massdiesel (on TDR) makes a custom tranny hose that has the probe bung built into it. It is $75.00 exchanged. After you put the new one on, you send him your old tranny line.
Old Aug 18, 2004 | 11:33 PM
SuperGewl's Avatar
Maybe its me, but most people don't worry about the tranny temp with a manual tranny
Old Aug 19, 2004 | 12:48 AM
John DiMartino's Avatar
Mike im not sure what size drain plug the 6 speed has,but if you can get a reducer,you can run the temp probe in the drain plug location,this would put it in direct contact with the fluid.
Old Aug 19, 2004 | 12:50 AM
Patrick Campbell's Avatar
ditto!
Old Aug 19, 2004 | 01:16 AM
Big Bob's Avatar
Upps, I didn't read the opening post very well. I was referring to an automatic transmission.
Thanks guys for opening my eyes!
rebel102285
May 19, 2009 11:08 AM
mar67655
Mar 21, 2009 05:35 AM
ngkefalides
0
Aug 12, 2008 08:33 PM
Nate-03 D
13
Apr 8, 2007 12:42 PM
