Trac bars
Trac bars
Soon I will be swapping out the factory trac bar. I have narrowed it down to the following 3. Money is not involved in the decision just want a good product. Which one would you pick?
1. Thuren adjustable trac bar
2. Carli Suspension adjustable trac bar
3. DT PROFAB trac bar kit
carli uses thurens track bar. with your leveling kit the adjustable is the only way to go, you can pull your axle back to center. I got mine straight from Don, been very happy. his customer service is top notch.
I am not sure that Carli uses the Thuren bar....
I have the Thuren and it is a solid peice. Very nicely built. That said if you are going to ever be running an axle forward lift it may contact your pitman arm because the bend over the front end gear is too sever.
jfranklin
Sep 28, 2007 01:19 PM
