Too Much Fuel Pressure...?
Old May 3, 2007 | 09:24 AM
isbeinside's Avatar
is there a such a thing as too much fuel pressure from your low pressure fuel system?
i plan on purchasing a FASS pump and found that they offer pumps that put out 45 to 50psi, i dont care to buy one now and then have to buy another one when i get the twin cp3's and injectors and all that good stuff.
Old May 3, 2007 | 09:41 AM
35" 05''s Avatar
these cp3's like 40lbs so everyone says. 35lbs WILL blow off your stock filter lid. Im runnin 25 right now.
Old May 3, 2007 | 09:58 AM
973604x4's Avatar
if you run 30 or higher, i would suggest a billet fuel filter lid.
I run 42psi....and have more months.
Old May 3, 2007 | 10:03 AM
Jfaulkner's Avatar
Muted User
I'm running an Aeromotive A1000 with the regulator set as low as it goes (30psi) without any problems. However I'm not using the factory filter housing. A local D-Max shop said that he tried to run 30 to his D-Max (which uses almost the same cp3) Wouldn't idle right at that PSI.
Old May 3, 2007 | 11:12 AM
isbeinside's Avatar
i do not intend to run the stock filter or housing (glacier delete kit), but at 45lbs, i have heard store from other dealership techs about blowing te seal off the front of the cp3 and filling the crank case with diesel but in almost 5 years of working on cummins in dealerships i have never had one come in.
Old May 3, 2007 | 11:27 AM
omaharam's Avatar
36psi. Stock filter lid.
jmlcolorado
Dec 16, 2009 04:43 AM
PourinDiesel
15
Jun 16, 2008 09:51 AM
Camarogenius
19
Mar 29, 2007 10:44 AM
snakefarmer
Jan 3, 2006 05:29 PM
Wes C
Dec 24, 2002 12:28 AM
