Toggle switch
Old Nov 30, 2005 | 11:04 PM
sr148's Avatar
Toggle switch
OK I need help I want to turn my fuel module on and off but there is only one wire that comes out of the module , do I connect that end to the toggle and then the other end to a ground or do i need to run it to the battery.
I am confused how does the module go on and off either way..
Old Dec 1, 2005 | 07:43 AM
sr148's Avatar
electrical Guru needed
any Electrical Gurus needed, not sure if on the toggle I need to connect to battery or just a ground..HElP...
Old Dec 1, 2005 | 07:38 PM
underwoodtransp's Avatar
I don't know you particular setup you are trying to install but If all else is not answered I would put ground to it first to see if it works. But more than likely you will need to supply a fused 12+ power source to get something to run!!. good luck
Old Dec 6, 2005 | 08:42 PM
JOHN LEWIS's Avatar
Predator
CONNECT THE YELLOW WIRE TO SWITCH THEN TO THE GROUND
Old Dec 6, 2005 | 08:45 PM
JOHN LEWIS's Avatar
Not Hot
DO NOT CONNECT 12V SOURCE YOU WILL BURN IT UP
Old Dec 6, 2005 | 09:20 PM
sawmillman's Avatar
If all you want to do is interupt the wire, all you do is cut the wire and put one end of the wire to one side of the switch and the other end to the other side of the switch. That way when you "open" the switch you just make a break in the one wire and when you "close" the switch the circuit is put back together. I am not sure just what you are trying to do but this is the way to interupt a single wire. Gene
big_bear_92007
Aug 15, 2007 10:35 PM
BearKiller
Nov 27, 2006 08:09 AM
G1625S
Oct 29, 2006 06:37 PM
CODODGE2500MAN
Off Road / 4x4
0
May 5, 2006 11:29 PM
JARHEAD
Dec 18, 2005 03:59 PM
