Thickness of alum. on willys Whistler pipe?
Old Dec 29, 2007 | 06:21 PM
sallyman1's Avatar
Thickness of alum. on ****** Whistler pipe?
How thick are the 2 aluminum pieces you welded onto the big pipe? (3/8" or 1/2")
Could a guy weld a nut on the one side for the filter minder? The MAF sensor has to lie flat though right?
Old Dec 29, 2007 | 06:46 PM
53 willys's Avatar
I think the IAT sensor is 1/2" and and the filter minder should not even be installed IMHO they are worthless on aftermarket intakes...PM sent
Old Dec 29, 2007 | 07:14 PM
rip 112's Avatar
^^^ I agree with the above, the filter minder is only sufficient for stock intakes in most cases.
Old Dec 29, 2007 | 09:55 PM
sallyman1's Avatar
okay thanks. whats a slit/quots?
Old Dec 29, 2007 | 09:57 PM
sallyman1's Avatar
also where would a guy mount the MAF sensor on the elbow? I might have trouble getting alu. welder or tig. A guy could silicone a wee bit under MAF sensor so theres no leaks to right?
sallyman1
Dec 31, 2007 06:33 PM
jasonstacked06
15
Dec 11, 2007 11:37 AM
proworks1
Jul 11, 2007 11:58 AM
DodgeDemon
Jun 27, 2007 10:14 AM
