surging problems??
After reading some posts on here my truck surges when accelerating hard. almost sounds like turbo bark too i know it sounds weird but its like a pulse. its my best describtion i could give.last time it was injectors dealer replaced them said they put in all six who knows there usaully rebuilds and there probably junk to begin with anyway. I was thinking of sending injectors to mid atlantic to loyd so i know they would be could. Someone was saying fca Do you check that or replace it? I just have smarty and an airdog 100 do I need a cp3 arson kit ? I need some guages so i dont know any pressures please help.
Well what are you running your smarty on? Thin you need to kinda figure out what you will be doing with the truck as far as what mods you need. If you want a truck up in the 450-500 range, the arson kit whould be ok, but if you want 600 and above you will need a moded pump, ( Floor It Diesel )
Yes it could be the fca and it sounds kinda like it may be to me, John at floor it can check them for you, and can mod the fca also, if you just need a little fuel. I dont think its your injectors, i would think you would have a hard start and a miss. Dodge will not change the fca so thats kinda hopless, they would want to change the whole pump, |
well my hopes would be 600hp at most after a turbo and injectors but then theres that darn thing called money and never enough of it but i didn't know if smarty was running the cp3 empty i run it on switch 9 4.11 would u say the diy kit or new cp3?
Originally Posted by coreydr2003
(Post 2304395)
Originally Posted by kdbvulcan
(Post 2304534)
is youre sticks on youre 03 as dead as mine??i just put Don's flux 2's in mine and cant tell no diff..supposed to be 100 horsepower sticks...hmmmmm
Originally Posted by tennessee
(Post 2304449)
ok so do think its cp3 related? when guys say throttle stay up a little after accelerating is that injectors cause my truck does that too but i thought that was boost just staying there if that makes any sense?
I wish there was some one around here who could take my truck for a ride and say ohh this is whats wrong..
Look in you chapter area from where your from, ask around, us the tool bar at the bottom and see where your chapers # is
(Post 2304575)
How much horsepower will each level of a floor it pump support?
were do you find chapter?
(Post 2304716)
https://www.dieseltruckresource.com/...ysprune=&f=152 |
Originally Posted by KKB
(Post 2304654)
I think in the next few months into summer we will be seeing trucks that will be in the 900 to 1000hp range with a single pump. Although there is a company that claims the are in the 900s with a single they are full of chet, they might be but it wasnt on fuel alone, some of us here know who this is...... |
