Superlift leveling kit - where to get?
I want to get the Superlift leveling kit with the bigger springs, but I cannot find a vendor that is selling the kit. Does anyone know of a good place to get the Superlift kit? Thanks.
njmaier
If you can't find the Superlift leveling kit - try the Rancho leveling kit. Comes with the hats instead of the springs so that you keep the stock ride. The kit also comes with longer traking arms so that you get more caster adjustment also. For the kit try 4wheelers supply and off road center 1 800 606 6421 talk to Cody. I have had the kit with rancho rs 9000 shocks on my truck now for 22,000 miles not a problem yet and rides just like stock. I think the price was very reasonable for the kit and the shocks.... Good luck....
Tim, with my setup if I got longer tracking arms, that would move my axle forward to origional stock position, right? My BFGs are rubbing the back of the wheel well on turns in conjuction with bumps. Also is there any need to get the spacer blocks for the front sway bar now that my truck is leveled. I saw some Kore aluminum spacers for $100 on their website and started wondering.
Thanks Jamie
Thanks Jamie
Jamie, everthing you stated above is correct. I was told the space blocks for the front sway bar are only needed when you lift the truck. Say for example a 4 inch lift. I run my truck through some rough stuff here in Arizona and get alot of articulation and havet had a problem yet. I don't know what kind of budget you have - I don't have much thats why I settled for the Rancho leveling kit - $180.00.
Call 4wheelers supply they are quite helpful.
http://www.rockymountainsusp.com/dodge4_03diesel.htm
I bought mine at a local 4wd store and they were only a few bucks more than the above link. The Superlift kit rides just fine, It's not any stiffer than stock.
Mindy
Sep 9, 2009 07:25 AM
schorb
14
Sep 2, 2005 03:49 PM
red rock
Feb 11, 2005 06:54 AM
Mark Thomas
Dec 17, 2004 12:17 AM
