Sumitomo/22.5/Optimus Snow Report!
Old Jan 22, 2007 | 10:10 PM
Bigduallywheels's Avatar
Originally Posted by D.Wiggs
No problem. They are good for AT LEAST 200,000 miles. You will most likely get more than that depending on use.
D wiggs think yours will last that long With all your power in that truck, I'll sure would hate to be your tires when you hammer on the gas!!
Old Jan 22, 2007 | 11:42 PM
D.Wiggs's Avatar
You and me both! I bet mine will last fairly long seeing as how mine are moving to my custom trailer since my new 295/75s will be riding on Optimus soon!
If not, they would probably only last 100,000 miles!
Old Jan 23, 2007 | 07:25 AM
signature600's Avatar
Question for you other "truck" tire users
What kind of pressure would you recommend for my "H" Range, 285/70R19.5's?? I have them at 100psi right now, and traction isn't a problem, but ride is. Just wondering how low I could go without sacrificing too much tire life??
Thanks Guys,
Chris
Old Jan 23, 2007 | 11:26 AM
cquestad's Avatar
35 psi........
Old Jan 23, 2007 | 11:37 AM
D.Wiggs's Avatar
Originally Posted by cquestad
35 psi........
Agreed....
Old Jan 23, 2007 | 11:45 AM
Really...don't have any swaying or cornering issues, even empty??
I might try going down to 60psi and see what happens..I don't really need to go down to 35, but we'll see!
Thanks Guys,
Chris
Old Jan 23, 2007 | 11:49 AM
D.Wiggs's Avatar
With these tires, they are so stiff, you need to factor in what they were designed to do. For example, my tires were meant to haul up to 6K per tire at 75 MPH. On the rear, they have about 800 lbs. on each of them; 13% of there actual capacity therefore you could run 13% of their max psi rating (120). 13% of 120 is 15.6 so you could run these down to 16psi and you would be within your limits. These tires are 16ply! You need to air them down just to get some flex in them!
I can tell you right now, go as LOW as you possibly can in the rears. the difference in ride and traction is night and day!
Old Jan 23, 2007 | 12:02 PM
Well I never thought about the percentages like that...I assume you'll air yours up when you hook to your trailer? I never know when I might need to hook to something, so I won't go too low as to not be safe when I'm loaded.
Chris
Old Jan 23, 2007 | 12:55 PM
D.Wiggs's Avatar
That's why I went to 25psi instead of like 16. This way, I can go up to 6000 lbs. on the rear tires and that would require about 2500lbs. worth of tonque weight which is more than I will ever have since I don't tow with anything other than bumper pull. I think 30-35psi in your case would be perfect.
Old Jan 23, 2007 | 01:09 PM
goodeyesniper75's Avatar
how is the ride on those tires anyway i was told by my 4x4 guy that he strongly recommends that i don't get them because they ride very rough and arnt very comfortable...is this true?
Old Jan 23, 2007 | 01:12 PM
D.Wiggs's Avatar
With the tires aired down, I notice no difference between them and the stockers and after my Thuren suspension is on, it will be like an escalade.
Old Jan 23, 2007 | 01:17 PM
thats cool...i would like to get them but dont know if i like the look of the tires...they arnt meaty enough for me i think
Old Jan 23, 2007 | 01:27 PM
D.Wiggs's Avatar
TOTALLY agree. That's why I am doing the 295s. They not only are wider by 2", but they have "beefier" tread on them as well. If you want highway tires, Michelin makes a 295/60 tire that is beefy and will fit on a stock heigh truck. It's just not for "bad" weather.
Old Jan 23, 2007 | 01:40 PM
yea i run around a lot on dirt and snow so i need somthing with a little grip.
Old Jan 23, 2007 | 01:54 PM
D.Wiggs's Avatar
Me too. I wish I could go wider, but the only thing I have seen are 305s and 315s that are like 43"+ Let me know if you find anything since you found those new goodyears!
