Started fabbing the Twins
You have the demonstrated fabbing skills to do this! I will say I think the details and the cost of the little parts cost as much as the turbos themselves! Another thread here had a link to things like hot pipes and cold pipes already done for certain set-ups. Be prepared to be patient!
like most my projects half way through I will say "why did I do this again"
Well This has really got me thinking. I was going to buy a big'ol single and rock it ..but after all the building twins threads I have been reading I think I am going to build me a set of twins for my 06..... myself
thanks for the inspiration 94ttss!!!!!!
*End Thread Jack*
do both your turbo oil drain/returns go into the same spot???
keep the pics coming.....lots of pics
thanks
Thanks for the faith in my fabbing
like most my projects have way through I will say "why did I do this again"
*End Thread Jack*
thanks
*End Thread Jack*
thanks
*End Thread Jack*
thanks
*End Thread Jack*
thanks
Mine uses the stock drain for the primary and then the small freeze plug by the oil filter is removed for the secondary. I don't see why you couldn't route two into one, but that seems like it would be a lot harder to do. You know, cheaper turbos like BHt3B-- you can buy two of those for almost the same as one expensive single... things to think about..
Still have to finish building the hot pipe and the down pipe, oil drain for the top charger, and oil feeds for both.
I'll post more pics soon. Thanks for all the compliments.
