Stage 2 Upgrades
Old Jan 13, 2006 | 11:25 PM
sporttees's Avatar
Question Stage 2 Upgrades
I HAVE INSTALLED A AFE INTAKE, MBRP DUAL EXAUST AND A TRIPLE DOG PROGRAMER W/ OUTLOOK MONITOR ON MY 05' DODGE 2500. WHAT WOULD BE A GOOD NEXT STEP? I'M WANTING TO END UP WITH AROUND 500 TO 600 HP.
Old Jan 13, 2006 | 11:32 PM
hognutz's Avatar
well I don't know if your 6 speed or auto but you will either need a tranny upgrade or clutch upgrade to even think about those power levels so I would start there.
if you have an auto you tranny is holding you back already. I know mine is. I could add power all day long but many tranny would just slip. I will not add any more power until this is remedied.
Old Jan 14, 2006 | 09:13 AM
RamWheelsBy4's Avatar
Fuel System, FASS or something to replace the stock lift/pusher pump. Big single turbo or twin turbos. I have the II SPS66 for now and will be switching to twins when I can afford it. TC/Trans or clutch addressed above, if auto probably at least TC, Valve Body and billet input shaft and flex plate. Get a TST PMCR for your primary performance box. That should get you between 500-600 usable rwhp.
Old Jan 15, 2006 | 12:35 AM
sporttees's Avatar
Red face Tranny Upgrade
Thanx For The Info. I Know Nothing About Tranny! it Is Auto! Where Would Be A Good Place To Start. Should I Get A New Performance Transmission Or Something Like A Banks Torqe Converter? Whats A Good Brand!
Thanx For Any Help
Old Jan 15, 2006 | 01:00 AM
TexasCTD's Avatar
Thanx For Any Help
Try here. http://dieseltrans.com/dodge/transmi...components.htm
Old Jan 15, 2006 | 01:03 AM
Its All Good's Avatar
I'm guessing your truck has low mileage on it so I wouldn't go out and buy a performance trans just yet. I would change the TC/VB and go from there. A lot of us are running different TC, look for one that will suit your needs. You can probably do a search on TC/VB and find a whole lot of info...
itsallgood
Old Jan 15, 2006 | 01:11 AM
TexasCTD's Avatar
itsallgood
I respectfully disagree. He said he wants to eventually make 500-600hp. With that in mind, it may be cheaper for him to go ahead and do the whole thing at once and do it right. But it won't be cheap.
I am still learning about this stuff myself, but I think that much HP (500-600) is to much for the stock tranny even with a TC/VB job. But I may just wind up doing the TC/VB myself if I can't come up the funds for the whole thing.
StrokeThis2500
Nov 15, 2006 05:17 PM
Doubleover
Apr 21, 2006 02:38 AM
052500#1
13
Jan 6, 2006 03:27 PM
timb
Aug 19, 2005 10:16 PM
