Stage 2 pump rp is 8k @ wot
Old Apr 18, 2008 | 09:17 PM
Lightman46's Avatar
Originally Posted by 44's n 454
before the pump and injectors were put in the rp would hit 23-25k all the time with smarty on sw9
It is either a Bad pump or the mechanic messed up putting in the injectors or there is a bad injector. to much return flow
Old Apr 18, 2008 | 09:35 PM
abc4yew's Avatar
If the FCA unplugged gives you a rail pressure of MAX then it sounds like you have some loose or illfitted injector connector tubes. Have the tech check the injector leak down... It seems cool to do everything at once but doing the pump....check the pressures then doing the injectors and checking pressure is the smarter way. Been there done this and everything else semi-tupid. KS
Old Apr 18, 2008 | 10:11 PM
soulezoo's Avatar
DTR 1st Sergeant
I have to agree with Kerry on this one.
Old Apr 20, 2008 | 06:40 PM
44's n 454's Avatar
what does a "leak down" tell you? does it tell if its the conector tubes? or just if there is a bad injector?
StrokeThis2500
Nov 15, 2006 05:17 PM
Doubleover
Apr 21, 2006 02:38 AM
052500#1
13
Jan 6, 2006 03:27 PM
timb
Aug 19, 2005 10:16 PM
