stacking ?
stacking ?
ok i just installed a power puck w/ my edge j/a and WOW!!! is this safe to do? i've got 99,800 miles on my truck and it's my daily driver and i don't want to break things. any advice for settings on the edge or what not to do? thanks in advance
If you don't want to break things then take it all off
!Now seriously,I don't know what the puck does(timing,duration,pressure?)But I know the edge does timing and duration and maybe some mild pressure.So you don't want to stack the puck if it is doing timing and duration also.If it is pressure only then you are good to go.
Hopefully someone will chime in with more experience on 04's, but heres what I beleive from what I have read before. The Juice on the 03-04 does timing, duration, and mild pressure, the Puck is pressure only. It should be fine with the puck on the 60hp setting, and on 90 for short runs. I ran this combo on my 04.5 for a while and never had any issues.
mcevins
Aug 30, 2003 11:09 PM
John_P
24
Jul 13, 2003 08:59 AM
Timinva
Nov 23, 2002 05:44 PM
