Stack threw the hood
yes, it is one of the few common rails with a p pump. he has a bunch of electronic gremlins to work out, because the cp3 is no longer there, and that was a while ago
t-boe-
the cp3 is replaced with the p-pump
viking-
I think the truck is sled pull only, but I am not sure
here are the only pics I have of a p-pumped common rail.
Ted--let me know if posting these pics is out of line, I will delete them if you want me to.
This topic comes up every couple months or so
hope this helps
viking-
hope this helps
wow!!! I bet that billet cover was not cheap....whats with the clear hose on the valve cover??? is that just the crank breather???
I love that this big burly truck still has the stock intake horn, I guess they must flow pretty good.....
wow good question t-boe I never thought of that
does it still have CR injectors???
one thing for sure is all the High HP &TQ trucks run a P-pump that has to tell us something......probably that we need a engine management program to make the most of our computerized engines.
There was a p-pumped 24 valve (green, 2wd, dually)at a dyno event in Buda TX, that put down 8XX hp, and maxed out the tq at 1500 ft lbs. A p-pumped conversion is hard to daily drive, from what I have read on here and other sites.
the conversion completely does away with the common rail setup. uses diff. injectors. the preasures are lower but not need for the injectors. the pics. with the clear hose was on a customers truck that i p-pumped just a little more breathing that way (clear hose helps moniter blow by you can tell if you are loosing oil or vaper). the conversions are not bad to drive on the street, just like any 12v engine if tuned right.
no problem on the pics thanks for posting them.
ted
ted
ted
ted
Was p pump mostly so you turn more rpms or what??
I mean a don't know what it takes to make a puller but a guess no one has made a cp3 or injectors big enough yet to get over 1k horsepower I would think a fair amount of drugs would be needed to get there to with the common rail.
